maybe you should cover the battery in a stocking hat for the winter
battery temperature sensor, pretty retarded.
I hate that they won't do anything anymore without the $95 dollar charge to run the codes, and god help you if you have a problem and it doesnt pull any codes, they'll tell you the problem doesn't exist. I think there are only a handful of actual mechanics left in the US now, technician is code for "reads machine then does what is told"
