Welcome to Jeepz.com.
Results 1 to 4 of 4
    PhattyX's Avatar
    PhattyX is offline Senior Member
    PhattyX is
    going a little crazy with 3 Jeeps in the family.
    Apr 2004
    Rofo Hold'em, PA
    255
    What years/models have the 258?
    I'm trying to find an oil dipstick for an '80 CJ5 with a straight 6. I initially assume it is the 4.2 (258 ). When calling a junkyard, what other vehicals can I say have the same motor? Do the 6 cyl YJ's have the 4.2 or the 4.0? Was that changed when FI was added? Did any of the Cherokee's have the 4.2 or just the 4.0?
    On a side note, I've seen headers in the Quadratec book for a 72-80 CJ w/ 232. Huh? I'm aware of the 225 V6 in older ones, but was a 232 offered or is this a mistake?
    Thanks all,
    -X
    If there's anyone capable of beating that moron at his own game, it's you, sir.
    Joopin's Avatar
    Joopin is offline Moderator
    Joopin is
    has no status.
    Dec 2002
    Neptune NJ
    2,417
    Type of Jeep
    YJ Wrangler
    Re: What years/models have the 258?
    The YJs came with the 4.2 up till 1991 which was the first year they put the FI 4.0 in the wrangler. I'm not sure if the XJs made the change at the same time or earlier... hopefully this narrowed it down for ya.
    Joop
    91 YJ 4.0 5spd
    SOA + 1.5" reverse eye RE springs
    D44 LS Rear & ZJ Disks
    4.56 gears
    36"x14.5" Parnelli Jones'
    Jks discos
    Warn XD9000i
    Banks SS exhaust
    High Steer!
    And a bunch of home made stuff!
    Stock 2005 Loaded WK, for now!
    yjdave's Avatar
    yjdave is offline Senior Member
    yjdave is
    has no status.
    Sep 2003
    portland,OR
    607
    cherokee's never used the 4.2...the 232 and 258 I-6 share most everything outside the block. Look for 70's early 80's AMC stuff like madador, eagle, and cjs ,yjs.
    [IMG]
    Junkpile's Avatar
    Junkpile is offline Senior Member
    Junkpile is
    has no status.
    Oct 2003
    Wilmington, NC
    2,313
    The 232 was a shorter stroke 258. The 232, 258, and 242(4.0) are all from the same engine family, the second gen AMC inline six. Alot of parts will interchange between the different engines. I would assume that any 232 or 258 dipstick and tube would work, not sure about the 4.0.
    Like already said, check AMC and early Eagle cars. Some mailtrucks had them. Fullsize Jeeps.
