This section Sponsored By
Old 04-01-2006, 05:31 PM
NCjeeper's Avatar
Real Name: ncjeeper
on-board air
im putting a 83 258 w/ ac into my 75 cj5. i dont plan on hooking up the ac or anything, as i'll have the top down every time its not raining (not my daily driver)... so my question is... what all is needed to use the a/c compressor for onboard air? i know i have to put an air filter in the intake line, i guess get a 5/8 to 1/4" adapter to run a air line to a tank, and get some sort of regulator?
View Public Profile Send a private message to %1$s Show NCjeeper gallery
Old 04-01-2006, 05:44 PM
LVRockCrawler's Avatar
Re: on-board air
on my old 91 (cant find a compressor setup for my 89w/serp. belt) all i did was ziptie a filter (used an foam lawnmower element cut to fit) on the intake side, kept it oiled w/compressor oil to lube the sanden compressor (york shouldn't be much different but the sanded doesnt have an oil sump), plumbed line along the inside frame rail to a regulator/switch (obtained used from a local compressor shop) and then to tank (portable from home depot) in the bed - the regulator was set for 125 max and 70 min, then wired to the master switch going to the hot wire on the compressor clutch - used this setup for 3 yrs+ w/out a problem - may not be a typical experience but worked for me and only cost about $50 in parts- could air a 32" tire in less than 2 min from 8lbs to 25lbs plus ran impacts etc.... gotta get mine set up again - i kept it simple and pretty basic - but you can get as extreme as you want.... just my $.02
Bob in Vegas
89 YJ-4.2/5spd,Herculiner tub,4"HellCreek Lift,Cable front axle,Flush LED tailights,Hella,KC,33x12.5 BFG M/T on Eagle Alloys,flatfender,55w backup lights, Steves Jeep Rear bumper,Bestop extendatrunk w/top mounted spare,Cobra CB w/rear dual antenna, misc. trail rash
View Public Profile Send a private message to %1$s Show LVRockCrawler gallery
Old 04-01-2006, 06:05 PM
NCjeeper's Avatar
Real Name: ncjeeper
Re: on-board air
Quote:
thats exactly what i thought i should do? ive only heard about OBA setups, i havent ever seen one or even know anyone, other than you, that has one. sooo.... i just put an air filter directly on the compressor, rig a line out, get a tank, and find a regulator...
how do i wire it?
  #4 (permalink)
Old 04-01-2006, 06:32 PM
TWDJ's Avatar
Jeep :
Year :
Lift :
Tires :
Cherokee
1993
Stock
30"
Real Name: Tom Dove
Re: on-board air
Here's a link I found while researching OBA for my rig. Looks complete to my semi-electrical/mechanical eyes.
This is the setup I plan to try after replacing all my suspension and cab bushings.
1993 XJ "Country", 4.0L, AW4, NP231, D30, C8.25, 30x9.5/15
View Public Profile Send a private message to %1$s Show TWDJ gallery TWDJ
  #5 (permalink)
Old 04-01-2006, 06:33 PM
Re: on-board air
yea... i just looked at what i had and figured what i had to do to make it work... a little trial and error but eventually "got er done!" worked sweet and didnt spend 400 bucks to do it... never let me down.... twdj - wheres the link?
Bob in Vegas
  #6 (permalink)
Old 04-01-2006, 07:30 PM
NCjeeper's Avatar
Real Name: ncjeeper
Re: on-board air
lvrockcrawler - how did you wire that?
twdj - pm me the link or re-post?
  #7 (permalink)
Old 04-01-2006, 07:38 PM
TWDJ's Avatar
Jeep :
Year :
Lift :
Tires :
Cherokee
1993
Stock
30"
Real Name: Tom Dove
Re: on-board air
Let's try this again with my eyes open. Here is the link to a good looking OBA conversion ... http://www.visi.com/~bsimon/jeep/my_air.html
  #8 (permalink)
Old 04-01-2006, 07:57 PM
Re: on-board air
Great post guys, I have air on my 89 YJ and have already rerouted the belt to bypass the AC compressor. I was planning on yanking the AC system, but now you guys have given me a much better alternative!! Thanks!
To Err is Human, To JEEP is Devine!!!!
View Public Profile Send a private message to %1$s Show texasjeeper gallery
  #9 (permalink)
Old 04-01-2006, 08:04 PM
NCjeeper's Avatar
Real Name: ncjeeper
Re: on-board air
:) glad we gave you a helpful idea
  #10 (permalink)
Old 04-01-2006, 09:58 PM
Re: on-board air
theres a wire running to the clutch... take that and run it thru a switch to the regulator... that way you can turn the compressor off at the switch and the regulator will control the pressure when turned on (its the wire running to the compressor that controls the clutch)
Bob in Vegas
  #11 (permalink)
Old 04-01-2006, 10:02 PM
Re: on-board air
texas.... you have an 89? 4 or 6 cyl? if 6 cyl - is it serpentine? send me pics of your setup or a good description of how its laid out... cant find an aftermarket compressor setup for my 89/258 w/serpentine...
Bob in Vegas
  #12 (permalink)
Old 04-01-2006, 11:04 PM
Utah_jeepster's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
TJ Wrangler
2001
4"
33"
Real Name: Steven
Send a message via AIM to Utah_jeepster Send a message via MSN to Utah_jeepster
Re: on-board air
There is something called a Coalescing Filter that you will need to put in line from your compressor heading to-wards your tank.
It catches two things one the oil blow by and any water.
Try Kirby Enterprises for parts and schematics.
The tricky part is not being able to drive it in....but being able to drive it out.
2001 TJ 4" of lift, long arm kit,ARB's F/R with a viair 450c. Custom front bumper,rocker panels, and sliders.
Only 220 miles to Moab
Only 1622 miles to Red's fridge full of (non-utahian) beer
View Public Profile Send a private message to %1$s Show Utah_jeepster gallery Utah_jeepster
  #13 (permalink)
Old 04-02-2006, 10:29 AM
Re: on-board air
LVrockccrawler - Mine is a 6 cyl with a serpentine belt, what e-mail and I'll send you a pick of the configuration. If you get any new info for the conversion, e-mail it to me jumpmaster22@hotmail.com
  #14 (permalink)
Old 04-02-2006, 10:27 PM
Re: on-board air
texas - sent you a P.M. w/my e-mail - thanks!
Bob in Vegas
 Subscribe to our RSS feed
