This section Sponsored By
Old 04-03-2006, 12:48 AM
NCjeeper's Avatar
Real Name: ncjeeper
axle swap
i have a chance to buy two Dana 44's, front disc rear drum, from an 88 wagoneer for $450...
my stock 30, 44, are 52.5" from drum to drum (outside to outside)
the dana 44's measure 62.5"... i know you guys will know better than anyone, what all would this swap entail? i know i'll need extended brake lines, new spring perches, a tie rod, a longer drag link, but how do i know it'll be the right size?
what else would i need?
View Public Profile Send a private message to %1$s Show NCjeeper gallery
Old 04-03-2006, 08:32 AM
Bounty__Hunter's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1995
6"
36"
Re: axle swap
I don't think the front D44 will work, the diff will be on the driver's side and your CJ has a pass. side diff.
Old 04-03-2006, 12:12 PM
Re: axle swap
Older 70's waggy's have passenger side diff's. You'll need one of those. Plan on the tire sticking out 5+ inches, might be a problem. Are you wanting to go real wide? If not just keep your d44/30 and beef up the 30 w/alloy shafts and put disc on the rear and you'd be set.
[IMG]
View Public Profile Send a private message to %1$s Show yjdave gallery
