Old 07-20-2003, 07:00 PM
Member
1046417
It is time to give my 95 YJ the 30,000 mile tune-up/check. I have to change the oil in the rear diff., how difficult is this? Do you just pull the bolt, drain and refill; or is there a special procedure I need to know about?
[addsig]
95 Baja Edition YJ. mango body, 2\" body lift, 31x10.50 Cooper Discoverer ST tires, nerf bars, chrome accessories.....more to come when the $ will allow.
View Public Profile Send a private message to %1$s Show rtoney9 gallery
1046425
well i depends...i think you can drain it by using a suction pump to suck all the old fluid out but the best way would be to remove the cover...that way you could check everything out and make sure all the gears are ok and look for shavings, broken teeth etc. If you do that you will have to buy some gasket to put it back on though so you wont have any leaks.[addsig]
View Public Profile Send a private message to %1$s Show RayOvac gallery
Message Board Statistics
Jeepz.com RSS2 Feed
Powered by vBulletin® Version 3.7.1
LinkBacks Enabled by vBSEO 3.1.0
