cap and rotor
So on a hunch this afternoon, I pulled the cap to inspect it and the rotor on my 97 TJ 2.5. What I found was black corrosion looking substance on the contacts for each plug wire and on the rotor point. There was some, although not as bad, on the center contact from the coil wire.
My question is, was this just a sign that the cap and rotor needed replaced (which I did) or is it a sign of something else wrong? coil possibly? anything else? thanks!
Nathan
