This section
Sponsored By
11-19-2006, 09:57 PM
Real Name: Matt League
My jeep is trying to kill me...
Well the steering in my jeep has never been what I'd call tight but since I put my lift on it's getting progressively worse. Right after the lift before i got it aligned i was scared to drive it. The guy who aligned it told me there is slack in the gear box and he tried but no getting rid of it. She drives straight as an arrow but it's me that's gonna kill myself with this steering. If i try to adjust my course i have to turn the wheel a good ways then it seems to oversteer so i'm constantly fighting to keep her on the road, but if i get her straight and let go of the wheel she'll drive straight all day. I know i've been saying it forever now but getting my tires in no later than a month and I'm scared they'll only make it worse. I'm guessing gear box but is there anywhere else i should be looking and how much is this gonna run me?
The poster formerly known as Red93...
'93YJ 4.0HO, 33x12.50r15 Maxxis Mudder Buckshots, 4.5 RE extreme-duty lift w/ 1" BL, 4.11 gears, Aussie locked front, 1in transfer case drop soon to be replaced by SYE/cv shaft, 2 memphis 10's pushed by a memphis pr500, custom bumpers made by me
http://www.myjeepspace.com/wrangl3r93
http://www.tnvjc.org/index.php
11-20-2006, 01:25 AM
Re: My jeep is trying to kill me...
Check out your drive shaft, I am getting the death wabble due to my drive shaft being messed up. Could be a number of things though, I can't really think of anything off the top of my head.
Silence will bring even the mightiest of men down to their knees.
11-20-2006, 01:54 AM
thats kinda the way mine is i believe most of my slack is in the gearbox as well .... did the guy tell you how to help adjust the lash on the gearbox ?? ... also have you replaced all the basic stuff like tierods ect..
| lethaldose's Arcade Awards |
11-20-2006, 11:04 AM
Moderator
Jeep :
Year :
Lift :
Tires :
Real Name: Steven
What you need to do is have a friend turn the steering wheel as you lay in front of your jeep, left and right while the jeep is running and when its off.
This will tell you if any of your tie-rod ends are blown, and where the play is coming from.(watching the pit man arm as he turns/long time will mean the gear box). Seeing laterial movment in the whole axle could mean nex bushings in the leaf springs.
Also look at your idler-arm and other steering componets, if there bent this could cause some flexing while turning the steering wheel.
The tricky part is not being able to drive it in....but being able to drive it out.
2001 TJ 4" of lift, long arm kit,ARB's F/R with a viair 450c. Custom front bumper,rocker panels, and sliders.
Only 220 miles to Moab Only 1622 miles to Red's fridge full of (non-utahian) beer
11-20-2006, 04:38 PM
Ok lifted it and tried to find where the loose steering is coming from. Pitman arm. It shifts around a little before the steering connects. I'm gonna try tightening it when i get home from work tonight not sure if i can get it to stop
11-20-2006, 07:02 PM
i read from an article i googled up about adjusting the gearbox lash/preload and it said the lock nut and adjuster is on the top of the box .. if that might help any ....
11-20-2006, 07:47 PM
From what Utah said and how you replied, sounds like you need to be shopping for a gearbox (if adjusting it doesn't cure it).
11-20-2006, 09:45 PM
How much is that gonna cost me?
Someone:Hey what'd you get for christmas?
Me:A gear box!
That same someone: heck yeah i've always wanted one of those!
| Thread Tools |
| Display Modes |
Linear Mode
