Old 01-03-2007, 05:33 PM
93 Wrangler air\fuel problems
hello i have a 93 sahara yj. the engine was just rebuilt and heres the problems. First it has problems starting up not everytime but most of the time. it won't rev past 4000 rpm and it has no power and bad gas millage. i have replaced the spark plugs, the wires, the TPS, the fuel filter, i have check the fuel pressure the compression i have ran injector cleaner through it and i just can't figure it out. i would take it back to the shop that rebuilt it but they screwed me over so i don't trust them.
story behind that is my buddy blew a rod i took it to them they rebuilt it and it went out again. they told me it failed because of pre detonation but i always thought a new engine could have pre det but oh well so they charged me again to fix it and after a week of getting it back this is happning so any help would be great i am stumped.
View Public Profile Send a private message to %1$s Show nuke0070 gallery
Old 01-03-2007, 07:05 PM
Re: 93 Wrangler air\fuel problems
Have all the plug wires in the correct firing order?
http://www.cardomain.com/memberpage/475506
- MONEY PIT!!!
- CHEERS TO QUEERS, MORE GIRLS FOR US!!!
View Public Profile Send a private message to %1$s Show Craig gallery Craig
Old 01-03-2007, 09:33 PM
mud4feet's Avatar
Might wanna check the o2 sensor(s)............when mine went bad (TJ), it wouldn't rev worth a crap, no power, and gas mileage was TERRIBLE. Just a thought.......nothing to do with the rebuild, but definitely effects performance.
View Public Profile Send a private message to %1$s Show mud4feet gallery mud4feet
  #4 (permalink)
Old 01-04-2007, 08:32 PM
yes the plugs are in the right fireing order and i just replaced the o2 sensor still nothing i am totally confused with this. I am out of things i can think of so any help would be nice
  #5 (permalink)
Old 01-04-2007, 08:36 PM
TwistedCopper's Avatar
Real Name: Harry
may be a clogged catalytic converter...
  #6 (permalink)
Old 01-04-2007, 08:38 PM
oh yeah i also unhooked the exhaust before the cat and still nothing
  #7 (permalink)
Old 01-05-2007, 07:51 PM
Are you getting any codes?, check engine light? If you can't figure it out, you could just pay the cash for some other shop to run a diagnostic on it.
- MONEY PIT!!!
  #8 (permalink)
Old 01-05-2007, 10:41 PM
i think thats the next step cause no check engine what kind of places do a good dio on vehicles?
  #9 (permalink)
Old 01-08-2007, 04:05 PM
jfrabat's Avatar
Send a message via MSN to jfrabat
You may want to check that (1) the engine is getting enough fuel (check fuel filter, do a fuel pressure test), and (2) that it is getting enough air (change air filter and check hoses, clean Throttle Body and intake manifold). If it neither, try reseting the computer; mine acted up a bit once.... Also, check the vacuum hoses for any leaks or disconected joints. Also had this problem on mine once.
Felipe
'94 YJ 2.5L, RE 4" Std Lift, Adv. Ad. SYE, Woods Shaft, Alloy Axles with ARB Lockers and 4.88 gears, 62mm TB and TB Spacer, 165A Alternator, Aluminum Rad, BRX Hoses, Taurus e-fan, DCC fan controller, K&N Filter, Gibson Cat-Back, Accell Coil, LiveWires, 19# injectors, 31" tires on AR 15" Outlaw II Wheels, Delta Xenon H4 Headlights, 100W KC Daylighters and 100W Slimlites (Fog), Riptech Wiperboy, Sony sound system (5.25" front, 6X9 rear and 12" SW with amp), Pavement Ends Targa Hard Top.
View Public Profile Send a private message to %1$s Show jfrabat gallery
Forum Jump
Message Board Statistics
Jeepz.com RSS2 Feed
