Old 01-13-2007, 10:04 AM
Fuel filter/ pressure regulator install order?
Going to install a Weber 34 on an 84 CJ. I have searched this forum and others and have the following question..Does the install go Fuel filter, fuel pressure reg. the carb or fuel pressure reg., fuel filter then carb? We will be using a 1 in/ 2 out fuel filter to prevent vapor lock. If we install filter, regulator then carb will the decrease in pressure created by the regulator force fuel through the filter bypass? Wouldn't it be best to reduce the fuel pressure then install the filter to prevent this? Thanks for the help. Rob
84 CJ7 w/ 258, T-176, Dana 300
View Public Profile Send a private message to %1$s Show RLBJeep gallery
Old 01-16-2007, 09:20 PM
LVRockCrawler's Avatar
Re: Fuel filter/ pressure regulator install order?
not an expert but i've always seen the regulator on the fenderwell or by the carb as the last thing b/4 entering the bowls as you want to know the pressure entering - makes sense as the filter can vary that pressure due to interference or blockage etc... look around for examples - hope it helps... and welcome to Jeepz!!!
Bob in Vegas
89 YJ-4.2/5spd,Herculiner tub,4"HellCreek Lift,Cable front axle,Flush LED,Hella,KC,33x12.5 BFG M/T on Eagle Alloys,flatfender,55w backup lights, Steves Jeep Rear bumper,Bestop extendatrunk w/top mounted spare,Cobra CB w/rear dual antenna, misc. trail rash
View Public Profile Send a private message to %1$s Show LVRockCrawler gallery
Old 01-17-2007, 10:56 AM
Thanks for the advice. I have installed a see through fuel filter before the fuel pump, then before the carb I installed the fuel pressure reg., and finally the 1 in/ 2 out fuel filter. If it does not run properly I will switch the pressure reg. and fuel filter. My main concern now is the correct installation of the required vac lines for the Weber. I am straight on the dist vac advance, pcv in and out but need help on the egr, cto, vapor canister and vac reservoir. I have searched various forums and have found diagrams, photos and am trying to combine them to get it right. Thank you, Rob
  #4 (permalink)
Old 02-01-2007, 10:27 PM
smell my dirty poodle's Avatar
not sure if this will help. my webber wouldnt work with a new adjustable regulator. ran great after i pulled the regulator off
View Public Profile Send a private message to %1$s Show smell my dirty poodle gallery
  #5 (permalink)
Old 02-02-2007, 06:42 AM
I installed the weber with FP regulator and it runs great. I installed a plastic see through fuel filter before the fuel pump then a hard line to the carb side of the engine and then installed the FPR and finally a 1 in/ 2 out fuel filter. Runs great and hopefully the fuel filter before the FPR will keep it clean.
  #6 (permalink)
Old 02-07-2007, 08:12 PM
good to hear it! you cant "over filter" your fuel so when in doubt... over do it!!!
Bob in Vegas
Forum Jump
Message Board Statistics
Jeepz.com RSS2 Feed
