04-19-2007, 06:33 PM
Member
4.0L Carb? No Carb?
I was taking to a buddy of mine today and we were discussing if a 4.0L Jeep engine ever came equiped with a carb? And neither one of us were sure of that answer, Can anyone shed some light on this situation it would be greatly appreciated.
04-19-2007, 07:32 PM
Moderator
Real Name: Jesse
Re: 4.0L Carb? No Carb?
4.0 is fuel injected, the 4.2 has a carb.
91 YJ 4.0 5spd
SOA + 1.5" reverse eye RE springs
D44 LS Rear 4.56 gears
36"x14.5" Parnelli Jones'
Jks discos
Warn XD9000i
Banks SS exhaust
High Steer!
And a bunch of home made stuff!
04-19-2007, 08:00 PM
Member
So The 4.0 L never came with a carb, Thanks Joopin.
04-20-2007, 11:19 AM
Real Name: Connor
The 4.0 is what replaced the 4.2L. The 4.2 had the carter carb. and then it was replaced with the fuel injected 4.0.
LR
03' Liberty, Rusty's K&N tube and filter, 2.5" Rusty's Suspension Lift, 31" Hercules Trail Diggers
04-20-2007, 11:45 AM
could you put a 4.2 intake on a 4.0 and run a carb on the 4.0??
04-20-2007, 12:31 PM
Real Name: Johnny
I would check to see if the early 4.0 in teh xj was carbed?
ford made a carbed 4.0 in teh late 70's early 80's in teh explorer truck (not the explorer you know as the SUV, but the original one, it was a cheap base model pickup)
-Johnny-
04-20-2007, 07:54 PM
Member
Thanks everyone for sheeding some light on this dilema, A question was brought to me by a friend was a 4.0L Jeep motor ever equiped with a carb? And I was not sure of this answer so thank you to everyone who answered my question I really appreciate it.
04-23-2007, 04:01 PM
Moderator
The injected 4.0L didn't replace the carbed 4.2L, they were used at the same time from '88-'90, the FI 4.0L in the XJ/MJ and the carbed 4.2L in the YJ. It was in '91 that the YJ adopted the FI 4.0L already in use on other models and changed the Renix system to an updated more reliable MPFI system.
The Chrysler 4.0L used in jeeps was never carbed.
You can use a 4.0L head ('91+ HO) on a 4.2L for a great power boost, so it stands to reason that the 4.0L intake and FI will adapt as well. The intake runners are higher on the HO head so you'll have to use large washers on the manifold bolts to hold everything on.
| Thread Tools |
| Display Modes |
Linear Mode
