Re: 94 YJ hard starting problem.
Seems the fuel pressure is the issue; it could be either the Fuel Pressure Regulator or the Fuel Pump that is leaking...
'94 YJ 2.5L, RE 4" Std Lift, Adv. Ad. SYE, Woods Shaft, 62mm TB and TB Spacer, 165A Alternator, Aluminum Rad, BRX Hoses, Taurus e-fan, Delta Control fan controller, K&N Filter, Gibson Cat-Back, Accell Coil, LiveWires, 19# injectors, 31" Dueler H/T on AR 15" Outlaw II Wheels, Delta Xenon H4 Headlights, 100W KC Daylighters and 100W Slimlites (Fog), Riptech Wiperboy, Sony sound system (5.25" front, 6X9 rear and 12" SW with amp), Pavement Ends Targa Hard Top or Best Top Soft Top.
