ok i admit i'm not a motor man...more body?frame and paint type , sooo anyway i did the nutter. the jeep would'nt idle before the nutter but ran fine on the road. now after the nutter it idles sweet but starts to die of without gas pedal on the road ?? it ran sweet for 3 blocks and then started stuttering and lost some power. it runs smooth as long as your on the gas and accelerating ...ok motor heads what gives ????
ok i think i found it...the line came off the thermo vac switch. hooked it up the the dist tee and now it roars ! a little sloppy on the idle now though...maybe clogging tubes ? i'll try to find the article on that idle prob !
I did the same thing to mine. Finally got tired of messing with it, and got Weber.
Problems solved all the way around. Better idle,better acceleration,better power,better mileage(If that's possible! But sure seemed like it)
