Old 10-24-2007, 08:38 PM
88YJ6's Avatar
Member
Send a message via AIM to 88YJ6
Shake
Hey I got a shaking when I let out the clutch and press hard on the accelerator. I can kinda feel the wobble in the accelerator, the clutch and the steering. I definitely do hear it coming from right about the rear diff.
View Public Profile Send a private message to %1$s Show 88YJ6 gallery
Old 10-25-2007, 12:57 AM
Bounty__Hunter's Avatar
Moderator
Re: Shake
Sounds like a ujoint getting ready to let go, or rear pinion bearings. That is if you haven't done any mods before the problem.
Old 10-25-2007, 02:15 AM
88YJ6's Avatar
Member
Re: Shake
no i havent done any mods, it doesnt sound like a u joint, my friend had that happen in his 4 runner and it sounded more like a bass that pulsed faster or slower depending on speed.
someone told me to check rear shock mounts in case axle is slipping around or check motor/tranny mount sound correct?
thanks for the input though i appreciate it
  #4 (permalink)
Old 10-25-2007, 11:01 AM
Moderator
Re: Shake
I guess it could be a bad mount, but I don't have a clue why you would check the rear shocks.
Have you closely inspected the ujoints or checked the rear pinion for any lateral play?
  #5 (permalink)
Old 10-25-2007, 11:02 AM
Moderator
Re: Shake
Also remove the front driveshaft to rule out the front 1/2 of the drivetrain.
  #6 (permalink)
Old 10-25-2007, 12:31 PM
currupt4130's Avatar
VT Hokie
Real Name: Sam
Send a message via AIM to currupt4130
Re: Shake
Throwout bearing?
94 YJ (daily driver)
06 VW (hardcore crawler)
View Public Profile Send a private message to %1$s Show currupt4130 gallery
  #7 (permalink)
Old 10-27-2007, 01:40 AM
slo-wrench44's Avatar
Re: Shake
chock the wheels put it in neutral and crawl under it. grab the driveshaft and twist it back and forth and push up and down on it. any more than 1/4 inch twist and any movement up or down at the cross's will be a bad u joint. easy to check. might as well rule it out right off the bat. takes 5 minutes.
88 yj sahara, 258 i 6 bored .040" . R.E. 4.5 extream duty lift kit. mc 2150 carb. 3" body lift. 4 KC dalighters. smitty built rock crawler front bumper. hurst shifter oba via york . duel batteries. 33" bfg mud terrains.
things to do:
re wireing my jeep currently, replaceing the steering column, takeing care of floor pan rot, por 15 floor, herculiner floor, fix rust on paintjob.
View Public Profile Send a private message to %1$s Show slo-wrench44 gallery
  #8 (permalink)
Old 10-27-2007, 01:41 AM
Re: Shake
sorry any more than 1/4 inch twist will be ring and pinion.
things to do:
  #9 (permalink)
Old 10-27-2007, 11:55 AM
TwistedCopper's Avatar
Real Name: Harry
Re: Shake
My first thought was U joints as well... have you ruled them out yet?
  #10 (permalink)
Old 10-27-2007, 06:00 PM
88YJ6's Avatar
Member
Re: Shake
is there an easy way to do check for u join problem? Im a college student with limited tools and my apartment complex is a ***** about stuff like jacking uo your car to do anything besides replace a flat tire.
  #11 (permalink)
Old 10-27-2007, 06:32 PM
VT Hokie
Real Name: Sam
Re: Shake
Grab the shaft and shake it. If there's excessive slop you'll know it. Apply force in multiple directions.
  #12 (permalink)
Old 10-27-2007, 08:22 PM
88YJ6's Avatar
Member
Re: Shake
ok so i just crawled under and check the output shaft from the transfer case to the rear axle with it in gear, no movement. With it in neutral just a small bit of radial movement but not a lot, I would guess its loose there. I also checked to see if the rear leafs were loose somewhere but didnt find play there or in the motor mounts...
could it be the tranny mounts?
  #13 (permalink)
Old 10-27-2007, 08:24 PM
88YJ6's Avatar
Member
Re: Shake
i didnt try moving the output laterally, if that makes sense, though
  #14 (permalink)
Old 10-27-2007, 09:59 PM
redrooster's Avatar
Re: Shake
My bet is still on u-joints, but check your motor mounts and transfer case mounts.
1622 Miles from Moab.
View Public Profile Send a private message to %1$s Show redrooster gallery
  #15 (permalink)
Old 10-28-2007, 08:07 AM
88YJ6's Avatar
Member
Re: Shake
is there an easy way to check the u joints?
  #16 (permalink)
Old 10-28-2007, 11:18 PM
redrooster's Avatar
Re: Shake
See posts 7 and 11. Try to move it side to side and up and down, it shouldn't move.
If you suspect the transfer case mount, lay on your back and see if you can push it back and forth with your foot. It also should not move.
Should be able to do a visual chack on the motor mounts or get a friend to put it in gear and let the clutch out while you watch. The engine will torque sideways to some extent, excessive movement will indicate bad mounts.
  #17 (permalink)
Old 10-29-2007, 12:23 AM
88YJ6's Avatar
Member
Re: Shake
yeah i grabbed the motor and shook it as hard as i could...
as far as the u joints am i grabbing the rear axle or the output shaft from the transfer case?
  #18 (permalink)
Old 10-29-2007, 05:19 AM
Re: Shake
both
things to do:
Forum Jump
Message Board Statistics
 Subscribe in a reader
