Quote:
Originally Posted by Bounty__Hunter
Sounds like a bad ASD relay (autoshutdown relay). Check out the owners manual for location, or check the pdc under the hood.
Swap out the ASD relay with another (like AC) for a quick check, or just replace it all together. Don't forget to have the trouble code reset with a scanner.
Switched the two relays, walked around to the door, horn didn't work,, Cleared the codes , so far so good....
Thanks so much for the help....
Rick....
