Old 11-27-2007, 02:50 PM
Real Name: John Grissom
YJ steering box
I've got a '94 YJ that has manual steering. I am looking to upgrade to power steering can anyone tell me if a steering box off a cherokee will work?
View Public Profile Send a private message to %1$s Show deerej4840@yahoo.com gallery
Old 11-28-2007, 04:15 AM
Bounty__Hunter's Avatar
Moderator
Re: YJ steering box
Yes, the entire PS setup from an XJ will work.
Old 11-28-2007, 07:31 PM
TwistedCopper's Avatar
Real Name: Harry
Re: YJ steering box
Just a reminder, it will rob you of a little power and fuel economy.
I had a 4 cyl YJ with manual steering, and I noticed it was a little stronger and a little better on fuel than a couple of other ones I drove. I think that unless you do alot of low speed steering or rock crawling then it is not worth converting it to power. If you do either of those than I could see it being a worthwhile trade-off.
  #4 (permalink)
Old 11-30-2007, 07:04 PM
Re: YJ steering box
It will be OK for now, I have a 383 ready to put in shortly.
  #5 (permalink)
Old 03-12-2008, 11:24 AM
Re: YJ steering box
I looked at my steering box on there now and it has 4 bolts holding it on, all the xj boxes I looked at have 3 bolts, and will the pitman arm work also?
97 Cummins
  #6 (permalink)
Old 03-12-2008, 04:58 PM
Moderator
Re: YJ steering box
It'll bolt up, but you'll need a pitman arm for power steering.
Consider picking up a steering box from a '98-'99 Durango as it is an upgrade.
  #7 (permalink)
Old 03-12-2008, 08:26 PM
Re: YJ steering box
Will the pitman arm from the xj work?
97 Cummins
  #8 (permalink)
Old 03-13-2008, 02:02 AM
Moderator
Re: YJ steering box
The XJ pitman arm will work, but it has about 1" more drop than a stock YJ arm. Good for use with a lift.
  #9 (permalink)
Old 03-13-2008, 12:37 PM
Re: YJ steering box
It has a 3" body lift now, I'm going to put shackles on so it should work.
97 Cummins
  #10 (permalink)
Old 03-13-2008, 03:46 PM
Moderator
Re: YJ steering box
Dude, 3" of body lift and longer shackles is not the proper way to lift. Consider getting away from both and installing some quality lift springs and you'll have fewer problems in the long run. Your jeep will be safer and perform better.
I wouldn't go over 1" in BL and no more than a 1" longer shackle. Any more and you put a lot of stress on the body mounts/bolts, and you mess with pinion angles and caster.
  #11 (permalink)
Old 03-13-2008, 04:03 PM
jfrabat's Avatar
Send a message via MSN to jfrabat
Re: YJ steering box
X2!
The longer the bolt on the body, the more leverage it will have in case of a collission (and this is not even considering rust!), which makes the jeep more dangerous. As for the shakles, the longer the shakle the more leverage it has on the body mount, and the more likely they are to fail (and they fail sometimes wven WITHOUT the help of the longer shackle, so you are expanding on an existing potential problem!).
I also recommend a good suspension lift.
Felipe
'94 YJ 2.5L, RE 4" Std Lift, Adv. Ad. SYE, Woods Shaft, Alloy Axles with ARB Lockers and 4.88 gears, 62mm TB and TB Spacer, 165A Alternator, Aluminum Rad, BRX Hoses, Taurus e-fan, DCC fan controller, K&N Filter, Gibson Cat-Back, Accell Coil, LiveWires, 19# injectors, 31" tires on AR 15" Outlaw II Wheels, Delta Xenon H4 Headlights, 100W KC Daylighters and 100W Slimlites (Fog), Riptech Wiperboy, Sony sound system (5.25" front, 6X9 rear and 12" SW with amp), Pavement Ends Targa Hard Top.
View Public Profile Send a private message to %1$s Show jfrabat gallery
  #12 (permalink)
Old 03-14-2008, 11:09 AM
Re: YJ steering box
It had the body lift on it when I bought it. It was a package deal that came with 2 cj7 tubs, 1 in excellent shape and 1 in fair shape. 1 cj7 frame completely refurbished, 2 complete front clips, a set of stock axles(AMC 20 & dana 30), turbo 350 tranny w/new TC, NP 205 and misc. parts. The YJ had new 33" boggers on it so I can't complain too much. Now it has the starting problem.
97 Cummins
Forum Jump
Message Board Statistics
 Subscribe in a reader
