84 CJ-7 won't stay running
When I try to start the engine catches and runs as long as it is cranking. When I return the key to run, it dies. Someone suggested that the coil wasn't getting enough power so I connected positive side of coil directly to battery. It runs, but it runs rough and I am sure the direct connect is not good for the coil. I also tried a new coil and had the same problem.
84 CJ-7
258 cu in
Howell TBI fuel injection
Any suggestions would be appreciated.
