This section Sponsored By
Old 01-16-2008, 09:26 AM
Member
Question Change rears = better fuel mileage?
I've got an '89 Wrangler that's a 4.2 & 5 speed right now..... I just bought a 2004 Wrangler 4.0 with the automatic trans & transfer case which I'm going to put in as soon as the weather warms up a bit.
Right now my gas mileage stinks & I know the 33x12 Thornbirds don't help.
I was wondering if I changed the rears to a 3.07 ratio vs what I've got now which has to be 4.11 or 4.56 would the effort and expense be worth it? Just had another thought - I wonder what the ratio was of the 2004 Wrangler that this engine came out of & if the computer is set up to recognize that & if I'm going to screw with some shifting ssignals etc......... hmmmmmmmmm...............
Any input would be appreciated,
Thanks - Jim
View Public Profile Send a private message to %1$s Show 60 Biscayne gallery
Old 01-16-2008, 11:30 AM
Member
Re: Change rears = better fuel mileage?
Anybody done this kind of swap that can Help...............
Jim
Old 01-16-2008, 11:38 AM
Wrangl3r93's Avatar
Real Name: Matt League
Send a message via AIM to Wrangl3r93
You'll lose considerable power trying to push those big tires and I would think drop your mileage even more by doing so. Although I have no experience with either engine personally. Someone is going to have to chime in and correct me but a stock 4.2 and 5 speed should have somewhere around 3.5? or 3.73 gearing already? I think only the 4bangers came from the factory with the 4.11 rear end.
The poster formerly known as Red93...
'93YJ 4.0HO, 33x12.50r15 Maxxis Mudder Buckshots, 4.5 RE extreme-duty lift w/ 1" BL, 4.11 gears, Aussie locked front, 1in transfer case drop soon to be replaced by SYE/cv shaft, 2 memphis 10's pushed by a memphis pr500, custom bumpers made by me
http://www.myjeepspace.com/wrangl3r93
http://www.tnvjc.org/index.php
View Public Profile Send a private message to %1$s Show Wrangl3r93 gallery
  #4 (permalink)
Old 01-16-2008, 02:45 PM
Member
Hay thanks,
If your right & the big tire situation is very logical by doing nothing would save me a 600 mile round trip to buy the 3.07 rears plus the purchase price, not to mention the labor to switch them over.
Gas money for my son's Dodge Hemi to go get them was scary plus the tolls........... Boy I feel like I just hit the lottery or something!
I always new that doing nothing would pay off someday!
  #5 (permalink)
Old 01-16-2008, 02:50 PM
mud4feet's Avatar
Quote:
Originally Posted by Wrangl3r93 View Post
.........Someone is going to have to chime in and correct me but a stock 4.2 and 5 speed should have somewhere around 3.5? or 3.73 gearing already? I think only the 4bangers came from the factory with the 4.11 rear end.
I believe you're correct. Beginning in '03, the Rubi's came with 4.11's, but prior to that, I believe only us 4banger owners were blessed with that gearing. Not sure of the gearing in the 6's, though.......I know it did vary.
View Public Profile Send a private message to %1$s Show mud4feet gallery mud4feet mud4feet's Arcade Awards Flash Poker Kullors
  #6 (permalink)
Old 01-16-2008, 03:02 PM
Wrangl3r93's Avatar
Yeah just got back from class so I have more time to search. Depends on the package you got I've seen from 3.07 to 3.73 on the i6's.
  #7 (permalink)
Old 01-17-2008, 02:38 AM
Bounty__Hunter's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1995
6"
36"
An '89 4.2L 5spd will have 3.07 gears from the factory.
If you want to regain power and improve mileage you will install lower (numerically higher) gears to offset the taller heavier tires. 4.11 would be a good swap and they were available in YJ's with the 4cyl 5spd. A lot cheaper and easier to buy the used 4cyl axles and swap them in complete.
Losing the Stuckbirds/Thornterds would help too, they are a very heavy bias-ply tire that sucks onroad and off. They're big with the show-truck crowd because they LOOK aggressive, but the long center tread blocks cause the tire to behave like slicks onroad and off. I've taken my tire groover to a few sets for other jeepers and it has helped 'some'. Get a decent radial MT, it will work much better onroad and off for you.
  #8 (permalink)
Old 01-17-2008, 01:47 PM
jps4jeep's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1994
3"
Q's the only TSL
Real Name: Johnny
Send a message via AIM to jps4jeep
Quote:
and cursed with only a hundred horse.
It used to be a jeep Thing,
But all that stuff broke
-Johnny-
View Public Profile Send a private message to %1$s Show jps4jeep gallery
  #9 (permalink)
Old 01-17-2008, 05:07 PM
LBR's Avatar
LBR LBR is offline
Real Name: Lance
Quote:
Originally Posted by 60 Biscayne View Post
Hay thanks,
Hi Jim - just curious where you reside that you can't pay a few $$$$ for delivery of a ring & pinion set instead of all the costly $$$$ and driving time horsing around listed above? No UPS or FedEx services available? LBR
Plant the wheelie bars and let the games begin
View Public Profile Send a private message to %1$s Show LBR gallery
  #10 (permalink)
Old 01-18-2008, 10:02 AM
redrooster's Avatar
I'm not sure about your computer compatibility with the swap. Install it and see what it does. I'm not up on the newer Jeeps and don't know if they had electronically controlled transmissions, anti-theft system or what. Worst case is that you have to get the computer flashed to rewrite the gearing and remove the anti-theft. Not a big deal.
I would think your mileage would increase slightly with the fuel injection anyhow. Put the engine and all in before you sweat the gears and tires.
1622 Miles from Moab.
View Public Profile Send a private message to %1$s Show redrooster gallery
  #11 (permalink)
Old 01-19-2008, 01:19 AM
Moderator
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1995
6"
36"
Quote:
More HP than the 4.2L
  #12 (permalink)
Old 01-24-2008, 09:17 PM
Member
Minus the Torq!
View Public Profile Send a private message to %1$s Show Megamole gallery
  #13 (permalink)
Old 01-24-2008, 09:21 PM
Member
As you can see in my sig I have 89 4.2L with a simaliar problem not as much tire as you but I can feel a difference. When my house gets finsihed and I finally have a warm garage to work in those axles will help out the milage and power of the 4.2L not to mention make 5th gear one I can use below 60-65mph
89 YJ Sahara, 4.2L Nuttered, TFI upgrade,weber carb,Borla catback, 3.5" Fabtech lift , 33" MTR's running 4.10s from a 4cyl
 Subscribe to our RSS feed
