Thread: Tranny Leaking
    djfred's Avatar
    djfred is offline Junior Member
    Jan 2008
    Santa Clarita, CA
    14
    Lightbulb Tranny Leaking
    Hey guys whats up
    I have a question.
    I was wondering if you guys would know of any quick and easy
    fix that i myself can do.
    Problem is my tranny is leaking oil, when i drive up and park i can notice it leaking couple of drops by the morning the puddle of oil is about 2 inch big.
    its not a lot but in the long run it is.
    Wondering without taking it to the Transmission guy that i know, to have him fix it for $250, you guys know any quick fixes that i can do until i take it to him when i get the time.
    thank you
    --Now--
    White 1992 YJ -- 4" Lift -- Tires 35x12.50x15 -- Magnaflow Exhaust & Cat -- K&N Air Filter -- Sanden OBA -- Dual Snorkel (Coming Soon)
    --Future Mod--
    Front D30 (4.88 w/ Powertrax No-Slip) -- Rear 8.8 (4.88 w/ ARB) -- Front Custom Bumper -- Custom Side Rock Guards
    currupt4130's Avatar
    currupt4130 is offline VT Hokie
    Jan 2004
    Blacksburg/Williamsburg VA
    2,573
    Re: Tranny Leaking
    You're gonna have to get under and tell us where it's leaking from and if it's an auto or manual
    06 VW (hardcore crawler)
    "The mountains are calling and I must go." -John Muir
    djfred's Avatar
    Jan 2008
    Santa Clarita, CA
    14
    Re: Tranny Leaking
    Its manual Tranny
    here are some pics i just snapped away
    After 4 Weeks of having the car this is what the Cardboard looks like.
    --Now--
    --Future Mod--
    lah2420's Avatar
    lah2420 is offline Senior Member
    Mar 2004
    Arkansas
    249
    Re: Tranny Leaking
    If you're sure it's the tranny, it is probably coming from the input seal. You have to drop the tranny to fix.
    If you're not sure it's the tranny, it could be the valve cover, leak around the oil pressure sensor, leak around the oil filter, or possibly even rear main seal. I would check everything else before dropping the tranny. I'm guessing valve cover. Remember that it's blowing back as you drive it.
    djfred's Avatar
    Jan 2008
    Santa Clarita, CA
    14
    Re: Tranny Leaking
    ill give those things a check in a little bit. ima clean up the tranny from grease then see where the leak is from
    thank you
    --Now--
    --Future Mod--
    Bounty__Hunter's Avatar
    Nov 2002
    Southern Illinois
    13,169
    Re: Tranny Leaking
    Looks like the rear main seal. Good chance your CCV system is clogged and you're building too much crankcase pressure, not properly venting it to the intake.
  7. #7
    mud4feet's Avatar
    mud4feet is offline Senior Member
    May 2004
    Smokey Mountains, NC
    3,909
    Re: Tranny Leaking
    Gotta agree with Bounty. From the oil build-up on the oil pan (way up above the drain), looks like it's been seeping from above, then as you drive, blowing over everything else. I would suggest a good cleaning of all that residue, then a prudent check after driving a little while............might shed a little more light on the problem. Good luck!
    Just Enjoy Every Possibility!
  8. #8
    Rompalicious's Avatar
    Rompalicious is offline Junior Member
    Nov 2007
    Tijeras, NM
    5
    Re: Tranny Leaking
    Yeah - I'm with the other guys here. Clean off the gunk until you get to the highest point of the leak... my guess is it's leaking back from the valve cover, or it's the rear main. Should be easy to see which when you scrub it down (or, should I say up... work from the lowest point upwards).
    Because... when you overcome that obstacle, it just feels Rompalicious.
  9. #9
    Jan 2004
    2,573
    Re: Tranny Leaking
    Quote Originally Posted by Bounty__Hunter View Post
    Mhmmm
  10. #10
    dandoc's Avatar
    dandoc is offline Senior Member
    Feb 2007
    Virginia, off I-95
    264
    Re: Tranny Leaking
    I had a similar problem in my '93 YJ. After replacing the valve cover gasket and cleaning out the CCV lines and elbow fittings, the engine oil blow-by into the air filter stopped, as did the oil drips onto the ground. When you go to the store for a replacement gasket, make sure it's the right one. Some kid at AutoZone tried to give me a 4 cylinder valve cover gasket when I needed a 6. Good thing I took the gasket out of the box before leaving the counter.
    '93 YJ, 6 cyl., 5 speed brought back to life over a period of a few months.
    Check out the restoration write-up of Project Salt (Pictures for May-August to come!)
  11. #11
    Nov 2002
    Southern Illinois
    13,169
    Re: Tranny Leaking
    To check for a clogged CCV system, find the tube connecting the rear of the valve cover with the airbox. Remove it at the airbox end and it should be sucking air into the engine with the jeep running. If it's blowing air out, your CCV is likely clogged. The clog is usually in the small line connecting the valve cover with the intake manifold. The line could be broken or the inline restriction orifice is clogged and needs cleaned.
  12. #12
    djfred's Avatar
    Jan 2008
    Santa Clarita, CA
    14
    Re: Tranny Leaking
    thank you guys all this information is awesome
    you guys rock
    --Now--
    --Future Mod--
  13. #13
    Dry suit diver's Avatar
    Dry suit diver is offline Senior Member
    Aug 2006
    London
    106
    Re: Tranny Leaking
    I have a similar sort of leak except there is no 'blow by' on the sump, it seems to be just over the tranny and everything rearwards, more to the right side of the vehicle (opposite side to the transfer case). any thoughts on the problem. I havent tried the CCV cleaning yet so am hoping that might be it.
    is the rear main seal easy to change on a I6 4ltr?
    some are born weird , others have weirdness thrust upon them
  14. #14
    shvlhd666's Avatar
    shvlhd666 is offline Senior Member
    Jan 2007
    Wichita, ks
    137
    Re: Tranny Leaking
    I did mine in about 5 hours. You don't have to unbolt the exhaust or the engine mounts like the service manual calls for.
    I just jacked it up on the frame until I had enough clearance to pull the pan.
  15. #15
    Aug 2006
    London
    106
    Re: Tranny Leaking
    Quote Originally Posted by shvlhd666 View Post
    its going into the shop then, no covered workspace here so I would be at the mercy of the british weather, bit of luck it might be the CCV overpressuring the motor or a leaky rockerbox gasket.
