Old 02-06-2008, 10:02 PM
lah2420's Avatar
My luck ran out. Tranny problem.
The jeep's been running good for several months. Today it gave me a new noise. On the way home, running in 5th gear, I started hearing a loud rattling noise and felt it in my shifter. It goes away when I downshift to 4th. I have a good idea what it is, but want to see what others say. It's an AX15.
View Public Profile Send a private message to %1$s Show lah2420 gallery
Old 02-09-2008, 09:32 AM
lah2420's Avatar
Re: My luck ran out. Tranny problem.
Any educated guesses out there? I'm getting ready to drop the tranny again. This is getting old. I just replaced an oil soaked clutch a few months ago.
When I bought the tranny, it was needing help. After rebuilding it, putting it in, and taking it out about 3 times, I found a slightly bent 5th gear shift rail. So I've had the 5th gear countershaft assembly apart about 3 times trying to see what was wrong. I didn't replace the snap ring the last times of tearing it down. I think that may be where my problem is. I'm guessing the snap ring has come off. If so, what's the trick to making it stay on? I'll be ordering whatever new parts I need, no matter how small this time.
Old 02-09-2008, 02:49 PM
redrooster's Avatar
That's gotta be aggravating. I don't know what snap ring you are talking about, but get a new one. Most industrial supply places will give you one. If that doesn't hold it in, try one size smaller if it's an external snap ring or one size bigger for internal. Make sure the groove is clean.
The good news is, you'll be an Ax15 expert by the time this is overwith.
1622 Miles from Moab.
View Public Profile Send a private message to %1$s Show redrooster gallery
  #4 (permalink)
Old 02-09-2008, 06:01 PM
currupt4130's Avatar
VT Hokie
Real Name: Sam
Send a message via AIM to currupt4130
Get a full circle snap ring of you can.
94 YJ (daily driver)
06 VW (hardcore crawler)
View Public Profile Send a private message to %1$s Show currupt4130 gallery
  #5 (permalink)
Old 02-09-2008, 07:10 PM
lah2420's Avatar
Quote:
That's a good idea. I'll have to check the thickness of it and see if I can find one. That should have been designed with one anyway.
  #6 (permalink)
Old 02-20-2008, 08:42 PM
lah2420's Avatar
Well, here's what happened. Any ideas why this would break? The counter 5th gear I replaced about a year ago still looks good.
  #7 (permalink)
Old 02-20-2008, 09:01 PM
jps4jeep's Avatar
Real Name: Johnny
Send a message via AIM to jps4jeep
ouch.. looks like some type of debris was in there, the way the teeth are squashed and not sheered
-Johnny-
View Public Profile Send a private message to %1$s Show jps4jeep gallery
  #8 (permalink)
Old 02-20-2008, 09:09 PM
lah2420's Avatar
It does look like they were squashed doesn't it? Actually, they are broken off. All the pieces were in the bottom of the tranny. One tooth was even nearly complete.
  #9 (permalink)
Old 02-21-2008, 12:52 AM
shvlhd666's Avatar
Real Name: Chris
Send a message via AIM to shvlhd666
Look for something in the debris that doesn't look like a tooth and look around to make sure something didn't break off from another part of the transmission.
Could be that one of the teeth just failed and ate the others up on the way out.
View Public Profile Send a private message to %1$s Show shvlhd666 gallery
  #10 (permalink)
Old 02-21-2008, 09:25 PM
lah2420's Avatar
I wish it hadn't been so stinkin' hungry.
Forum Jump
Message Board Statistics
 Subscribe in a reader
