02-17-2008, 04:06 PM
Real Name: Rebecca
random questions...
Few questions...
What class hitch do I need for a 91 YJ?
How big can I go with tires before I need to lift it?
Do the mirror relocater brackets from quadratec or jc whitney work with 1/2 steel doors, or will I need to take them off every time I want to put the doors back on?
What size speakers fit the dash mounted speaker grills?
And lastly, and most important....
I recently changed front and rear U joints to eliminate a clicking I was experience. That worked fine, no more clicking.. But now the little beast won't go into 4wd... Any one have ANY ideas as to why?
Thank you all in advance =)
Rebecca
02-17-2008, 04:16 PM
VT Hokie
Real Name: Sam
Re: random questions...
Quote:
Originally Posted by EMTSerks
Few questions...
Depends on what you want to tow. A class III is required by lots of clubs if you are gonna use it as a recovery point. Class III should be enough for anything you'll be able to tow with the Jeep.
31" I think...
This style Mirror Bracket allows you to still use the doors. However you gotta be careful not to hit them every time you open the door with the windows in.
4x6
Can you not physically move the lever to 4WD or does it not engage when you shift into 4wd. Probably the vacuum disconnect up front if it's the second case. Pull the vacuum plug off it and test to see if you have any vacuum pressure going to it.
Rebecca
94 YJ (daily driver)
06 VW (hardcore crawler)
02-17-2008, 11:10 PM
VT Hokie
Real Name: Sam
Damn did I seriously kill that question that well?
02-18-2008, 07:48 AM
Administrator
Real Name: Terry Mason
2005 Wrangler - 2" lift, 31" wheels, in-seat subwoofer
PM me for a free Jeepz.com sticker
02-18-2008, 08:47 AM
Few questions...
I would advise against replacing these speakers, and would advise you to use some other location (I got kickboxes under my doors, but there are other options).
The reason is that the location for these speakers is really poor, and they take away from the sound you will have. Granted, they LOOK nice where they are, but (1) they are a PITA to work on, and (2) they are positioned in such a way that the passanger will have a hard time listening to the driver side speaker and vice-versa.
You can see in my YJ how I installed the speakers here (Adding a TJ subwoofer)
By the way, I think Corrupt is right for the other questions...
Felipe
'94 YJ 2.5L, RE 4" Std Lift, Adv. Ad. SYE, Woods Shaft, Alloy Axles with ARB Lockers and 4.88 gears, 62mm TB and TB Spacer, 165A Alternator, Aluminum Rad, BRX Hoses, Taurus e-fan, DCC fan controller, K&N Filter, Gibson Cat-Back, Accell Coil, LiveWires, 19# injectors, 31" tires on AR 15" Outlaw II Wheels, Delta Xenon H4 Headlights, 100W KC Daylighters and 100W Slimlites (Fog), Riptech Wiperboy, Sony sound system (5.25" front, 6X9 rear and 12" SW with amp), Pavement Ends Targa Hard Top.
02-18-2008, 07:29 PM
Quote:
 .......LBR
Plant the wheelie bars and let the games begin
02-18-2008, 08:17 PM
VT Hokie
Real Name: Sam
Felipe
I got the 6x9 boxes that go behind the front seats b/w the roll bar and fender. They worked really well. If you can replace the ones in the dash, replace them with something that's gonna last cuz they are a PITA to get to. They're worth replacing if they're busted or if you're upgrading b/c you're only going to ruin your overall quality otherwise.
02-22-2008, 02:38 AM
Real Name: Ed
i have a random question for you,jeepsters.... more of a b'lieve me, i saw it with my own eyes. the Q- how long did AMC use Duct tape to insulate their slices in a wiring harness? I'm the second owner of my 82 cj7, and the guy before me was uh... less than a do-it yourself'r I just finished my dash and decided to clean up the stuff i wont need, after un-(i wont call it tape more of a black plastic wrap) the harness, there were multiple duct tape wraps on brass crimped splices... if you ever want to purposely give yourself a migraine... feel free to start the same project on your own,,, calgon could not take me away from this nightmare. It's like that 12 days of christmas farse... "rigging up the lights.ONE STARTS BLINKING, THEY ALL START BLINKING!"
02-22-2008, 06:32 AM
lol are you sure its not just really old grey electrical tape ? just a thought
88 yj sahara, 258 i 6 bored .040" . R.E. 4.5 extream duty lift kit. mc 2150 carb. 3" body lift. 4 KC dalighters. smitty built rock crawler front bumper. hurst shifter oba via york . duel batteries. 33" bfg mud terrains.
things to do:
re wireing my jeep currently, replaceing the steering column, takeing care of floor pan rot, por 15 floor, herculiner floor, fix rust on paintjob.
02-24-2008, 01:05 PM
Real Name: Ed
well, I haven't got the lab results back from CSI yet, but my training and experience leave me to believe, that with in a reasonable doubt... this may infact be 100-mile-an-hour tape.
02-24-2008, 03:54 PM
Quote:
LOLOLOLOLOLOL...................................mo te the sarcasim
02-26-2008, 02:58 PM
There is one thing that is certain in life and that is the uncertainty of CJ wiring. Welcome to Jeepz.
1622 Miles from Moab.
| Thread Tools |
| Display Modes |
Linear Mode
