Welcome to Jeepz.com.
Results 1 to 5 of 5
    Troubleshooter's Avatar
    Troubleshooter is offline Junior Member
    Troubleshooter is
    has no status.
    Feb 2008
    5
    1980 CJ7 4wd not engaging
    Hey everyone,
    New to the forum, new to Jeeps as well. Bought a fixer upper, and a plastic gas tank and new brake lines later, I have a running '80 CJ7 Renegade with a snowplow on the front. Problem is, it's only 1-wheel drive right now, I can only plow on level ground and need to get this 4wd fixed.
    Have it in the shop right now, pulled the bolts out of the left manual hub down at the wheel. The plastic selector seems to turn 360 and won't stop. Also, when I push this hub back on by hand and rotate, I'm getting the joint / knuckle to spin with this action like it is engaged. I don't know if I just released something or what when I pulled it off.
    I do not have a manual yet and looking for recommendations to which one would be best?
    I am trying to do this before I can get my hands on a manual though. Main question; where are the top 5 places to start when your 4wd won't engage.
    Shifter works, light comes on in Hi and Low. I am going out now to see if I can lift it up off the ground for any drive shaft action.
    New finding - 2-18-08 5:35 p.m.
    I lifted Jeep - all wheels off the ground; Looks like I have back wheels turning and front drive shaft turning. So either something is wrong in the axle?? or I have a problem with both lockouts engaging??
    Thank you,
    Troubleshooter
    B'ham Jeeper's Avatar
    B'ham Jeeper is offline Senior Member
    B'ham Jeeper is
    has no status.
    Jul 2007
    Birmingham, AL
    518
    Type of Jeep
    JK Wrangler
    Re: 1980 CJ7 4wd not engaging
    Sorry I can't help you with your problem but wanted to welcome you to jeepz. I am sure some of the guys around here will be able to help you with any problems.
    Red Neckerson's Avatar
    Red Neckerson is offline Senior Member
    Red Neckerson is
    has no status.
    May 2007
    Kansas
    353
    First of all, WELCOME!!
    If it were me, I would replace your front hubs with the Premium WARN.
    It has been a while since I have been into the front end of a CJ, but I would pull the hubs, repack the wheel bearings and replace the wore out-lock outs with some WARN Lock outs. Just my .02 To me, the lock-outs sound like they are shot.
    Anybody else have ideas?
    Troubleshooter is
    has no status.
    Feb 2008
    5
    Quote Originally Posted by Red Neckerson View Post
    Thanks RED,
    You were right, I pulled the left hub off and didn't understand how it worked at first until I disassembled it. Parts flew everywhere :) my kind of tinkering! Anyway, the good news is that they are "Warn" and after removing all the old grease and understanding the small plastic ring (nut) that holds the spring between the plastic bushing and turn selector, I finally pressed it in hard enough to thread it back on like it's supposed to be. If this is not started in the right position, the gear won't engage properly. The right one was just plain froze up, needing some cleaning so it would slide in and out when turning the selector. Fairly simple once one digs into it.
    Bad news is that I found that my knuckles on each side need the joints replaced, pretty well worn out. It has 62K miles and have heard from second owner that the snowplow was on it from day one.
    I appreciate it RED for your input! I pray that GOD will bless you in a mighty way!
    Troubleshooter
    Red Neckerson is
    has no status.
    May 2007
    Kansas
    353
    Glad to be of some help! I hope you enjoy your CJ. I have had two over the years and have a 98 TJ now. I still miss the CJ"s though!
    Hey, how 'bout posting some pics of your new ride?!
    Edit:
    BTW, It's good that you found the bad joints. Better now than later! I would really go over the entire Jeep and check EVERYTHING (fluids, driveline, steering ETC..) especially since it has had the snowplow on the front. Also I would change out all the fluids and refill with fresh. Again, just my .02
  1. 1980 CJ-7 For sale WISCONSIN
    By Cool Hand in forum Items for Sale, Trade, or Give Away
    Last Post: 11-19-2007, 08:11 PM
  2. 1980 CJ5 w/ 4.01 For sale
    By tlhamilton15 in forum Items for Sale, Trade, or Give Away
    Last Post: 02-19-2007, 08:09 PM
  3. 1980 CJ7 All there, no drivetrain
    By mtojoe in forum Items for Sale, Trade, or Give Away
    Last Post: 02-04-2007, 03:13 PM
  4. 1980 Jeep CJ7.....$3,800
    By carnut1313 in forum Items for Sale, Trade, or Give Away
    Last Post: 04-25-2006, 03:52 PM
  5. 1980 cj5 for sale south central pa
    By jeep90 in forum Items for Sale, Trade, or Give Away
    Last Post: 03-07-2004, 11:59 AM
