Old 02-18-2008, 07:24 PM
88YJ6's Avatar
Member
Send a message via AIM to 88YJ6
Body Lift
Hey so I am looking to get a little more clearance on my YJ and was thinking about doing a body lift. It looks fairly simple and cheap as far as lifts go. I was only planning on doing a 1" lift. I read a walk through for a TJ, and everything seemed easy enough to do as long as you have jackstands and a place to work. I was wondering if anyone has installed one on a YJ, just to get a bearing on difficulty and time involved.
88 YJ 6, stock except for new AMC I-6
Wants: Herculiner, AX-15 or NV3350, OX Locker
View Public Profile Send a private message to %1$s Show 88YJ6 gallery
Old 02-18-2008, 08:20 PM
currupt4130's Avatar
VT Hokie
Real Name: Sam
Send a message via AIM to currupt4130
Re: Body Lift
Quote:
One inch is as much as you really want to go. It's very simple. Just shoot all the bolts down before hand. The hardest ones to do are the ones under the Jeep on the x-member in front of the gas tank. If you start on it and don't stop to eat lunch, walk the dog, w/e, you should be able to knock it out in about 2 hours with hand tools.
94 YJ (daily driver)
06 VW (hardcore crawler)
View Public Profile Send a private message to %1$s Show currupt4130 gallery
Old 02-18-2008, 09:30 PM
TerryMason's Avatar
Administrator
Real Name: Terry Mason
Send a message via AIM to TerryMason
Re: Body Lift
I did a 1" body lift on my old CJ, and the hardest part was getting the old bolts out - I ended up braking / cutting a couple. You really need to oil the bolts for a couple of days prior.
Get one of the kits that have one piece body mounts that replace your existing old body mounts (not just some pucks to add to your existing mounts) Also make sure to use new bolts (they will come with a full kit).
2005 Wrangler - 2" lift, 31" wheels, in-seat subwoofer
PM me for a free Jeepz.com sticker
View Public Profile Send a private message to %1$s Show TerryMason gallery TerryMason
  #4 (permalink)
Old 02-19-2008, 08:21 PM
Bounty__Hunter's Avatar
Moderator
Re: Body Lift
I used 11 hockey pucks and 11 grade 8 bolts 1" longer than stock. Cost: $25.
Real easy to install, just loosen all the body bolts and only remove one side at a time, jacking the tub up with a floorjack. Hand tighten the first side then move to the other side.
Check fan shroud clearance, move the shroud down or cut the bottom to clear the fan. Or install an electric fan.
  #5 (permalink)
Old 02-21-2008, 11:11 PM
dandoc's Avatar
Real Name: Dan
Re: Body Lift
If it's an '88 YJ you're looking to do the body lift on, be prepared for rusted and seized body mount bolts. In order to remove my rusted bolts ('93 YJ), I had to cut the floor at the seats around the bolt heads and remove the entire bolt/nut/nut housing setup. This was after liberally spraying with PB Blaster for a few days, using heat (oxy-acetylene), AND an impact wrench. Two bolts are above the fuel tank (which you'll need to remove to access the bolts). Have fun! Any more questions, feel free to ask.
'93 YJ, 6 cyl., 5 speed brought back to life over a period of a few months.
Check out the restoration write-up of Project Salt (Pictures for May-August to come soon!) http://www.geocities.com/dandoc.geo/Jeep/yj_index.html
View Public Profile Send a private message to %1$s Show dandoc gallery
  #6 (permalink)
Old 02-24-2008, 03:50 AM
88YJ6's Avatar
Member
Re: Body Lift
Thanks for the input guys...
One question
Is the fan shroud mounted to the frame or why does everyone keep talking about moving the fan shroud?
Oh and also did anyone have any problems with any hose lenghts or wire lengths?
  #7 (permalink)
Old 02-24-2008, 05:23 AM
Moderator
Re: Body Lift
Hose lengths and wire lengths are generally okay on YJ's with a 1" BL.
The fan shroud moves up with the body lift as it's attached to the radiator which is attached to the grill. The engine and fan stay in place as the engine is attached to the frame. Thus the fan generally contacts the bottom of the shroud after a BL.
  #8 (permalink)
Old 02-24-2008, 12:32 PM
VT Hokie
Real Name: Sam
Re: Body Lift
With a 1" it might not be necessary to move the fan shroud, I don't think mine hit.
  #9 (permalink)
Old 02-24-2008, 03:53 PM
88YJ6's Avatar
Member
Re: Body Lift
Thanks guys
Forum Jump
Body Lift TerryMason Suspension 2 01-26-2008 04:31 AM
future problems with a body lift? LGR CJ YJ TJ and JK 1 06-28-2004 03:23 AM
Best Body Lift? Robert_Strausberg CJ YJ TJ and JK 3 01-27-2004 06:07 PM
Questions about a body lift Merlin CJ YJ TJ and JK 5 11-06-2003 09:36 PM
Got a new TJ, with a body lift from the dealer barlows CJ YJ TJ and JK 5 08-19-2003 03:21 AM
Message Board Statistics
 Subscribe in a reader
