02-25-2008, 06:09 PM
Member
Real Name: zach
32" on a budget
I posted earlier and asked if my 32x12.50-15 baja claws would fit. the only reply i got was practically "absolutely not". well, they did so..... here is what i did.
2" longer shackles (6", added 1" of lift)
15"x7" wheels with 4" backspacing
trimmed the 1.25" lip off of my flairs
Everything fit and the only rubbing i am having is when i turn the wheel all the way. this was fixed by adjusting my steering stops.
NOTES: i am only driving this on the street until i get my 4" lift next month!!!! I cannot guarantee no rubbing offroad or with swaybars disconnected!!!I also will not be doing ANY offroading until I get my lift!!!
Buy it, build it, break it, rinse and repeat!!
90 yj, 4.2, ax-15, camo, grant steering wheel, flipped license plate mount, kc daylighters, 4" lift, custom front and rear bumpers, herculiner, trimmed fender flairs, proline style 139 15x7 wheels, 33x12.50-15 baja claws, and mud; lots and lots of mud.
02-25-2008, 06:13 PM
Administrator
Real Name: Terry Mason
Re: 32" on a budget
Very cool - post so photos, I'd like to see how they look.
2005 Wrangler - 2" lift, 31" wheels, in-seat subwoofer
PM me for a free Jeepz.com sticker
02-25-2008, 07:25 PM
Member
Real Name: zach
Re: 32" on a budget
i will post some tonight after i get home.. it looks awesome and i love it.
02-25-2008, 07:28 PM
Moderator
Re: 32" on a budget
Quote:
You didn't mention trimming your fender flares as being an option. I still stand by them not fitting on the rear with only a 1" shackle lift. YJ's have some pretty tight rear fenders.
You should consider installing TJ flares if you want good tire clearance without the hacked up appearance.
02-25-2008, 07:59 PM
Member
Real Name: zach
Re: 32" on a budget
they dont look hacked at all but i do plan on lifting and doing front and rear tube fenders eventually. how do you post pics on here?????
02-25-2008, 08:01 PM
Member
Real Name: zach
Re: 32" on a budget
ok i hope i figured it out....
02-25-2008, 08:02 PM
Member
Real Name: zach
Re: 32" on a budget
some more..
02-25-2008, 08:04 PM
Member
Real Name: zach
Re: 32" on a budget
a few more.. pic 5 is showing 21" from driveway to bottom of tub.
Reason: extra info
02-25-2008, 08:05 PM
Member
Real Name: zach
Re: 32" on a budget
and the rest...
02-25-2008, 08:08 PM
Member
Real Name: zach
Re: 32" on a budget
i didn't mention the trimming as being an option but i did say that i was going to try it today and it worked.. trimming the fenders was pretty easy with the cutoff wheel and only took about 30 min to get them right. my flairs do look a little F...ed up but that is because my fender is slightly bent from a tree jumping out in front of me....
02-25-2008, 08:25 PM
Re: 32" on a budget
02-25-2008, 08:36 PM
Member
Real Name: zach
Re: 32" on a budget
thanx....they are actually 33s but the tread has worn down to about 32.25". they came off of my street queen (sisters) jeep after we put on the 33" all terrains. Not too bad of an upgrade for nearly free!!!(wheels i had laying around,tires were off of the white 90, cutting was about $10 for the cutoff wheel at pepboys.)
02-25-2008, 10:15 PM
Moderator
Re: 32" on a budget
That line in the YJ flares makes for an easy trim line, doesn't it?
I think you'll still get a lot of rubbing with rear seat passengers or any axle articulation.
I'm digging the camo.
Real Name: Devin
Re: 32" on a budget
Nice lookin jeep. What 4in. lift are you looking at? Curious because I'm going about the same route.
Shift into a higher gear, put a brick on the gas
on what I've left behind, I won't waste a tear
my rearview mirror has got broken glass.
02-25-2008, 11:38 PM
Real Name: Chris
Re: 32" on a budget
Did you apply the camo yourself?
02-26-2008, 10:47 AM
Member
Real Name: zach
Re: 32" on a budget
i am looking at either rough country or superlift, havent decided which one i want yet. the camo is just a vinyl wrap and it was on it when i got it. I bought the jeep from the place that does it and they said that they usually charge about $900 to wrap it. check with any local sign shop and they may be able to send you in the right direction on how to get it done.
02-26-2008, 10:48 AM
Member
Real Name: zach
Re: 32" on a budget
i rode last night with a couple of buddies to the store, both weigh about 200 lbs and i went through my friends yard on the way (very rough and hilly) with no rubbing but articulation would cause it to rub.
| Thread Tools |
| Display Modes |
Linear Mode
