Old 03-09-2008, 05:16 PM
EMTSerks's Avatar
Real Name: Rebecca
Send a message via AIM to EMTSerks
Roll cage questions
So I have a 91 yj... and the roll cage extends to the windshield... and those bars, that extend, are secured to the rest of the roll cage with some sort of securing device that I am unable to distinguish... What are they, how do I get them the hell off, and what special tool do I need??
Thanks in advance
View Public Profile Send a private message to %1$s Show EMTSerks gallery
Old 03-09-2008, 07:01 PM
jfrabat's Avatar
Send a message via MSN to jfrabat
Re: Roll cage questions
You mean the Otrx screws? I think a picture would help here, but if it is the stock sport cage, it should only be fixed with a couple of torx head screws...
'94 YJ 2.5L, RE 4" Std Lift, Adv. Ad. SYE, Woods Shaft, Alloy Axles with ARB Lockers and 4.88 gears, 62mm TB and TB Spacer, 165A Alternator, Aluminum Rad, BRX Hoses, Taurus e-fan, DCC fan controller, K&N Filter, Gibson Cat-Back, Accell Coil, LiveWires, 19# injectors, 31" tires on AR 15" Outlaw II Wheels, Delta Xenon H4 Headlights, 100W KC Daylighters and 100W Slimlites (Fog), Riptech Wiperboy, Sony sound system (5.25" front, 6X9 rear and 12" SW with amp), Pavement Ends Targa Hard Top.
View Public Profile Send a private message to %1$s Show jfrabat gallery
Old 03-09-2008, 09:54 PM
Bounty__Hunter's Avatar
Moderator
Torx bolts, they make special torx sockets. If some of them have a small dimple in the middle of the torx hole, then you need a set of tamper-proof torx sockets. I'm thinking the bolts that attach the spreader bars to the main hoop are tamper-proof.
  #4 (permalink)
Old 03-09-2008, 11:52 PM
currupt4130's Avatar
VT Hokie
Real Name: Sam
Send a message via AIM to currupt4130
I just got on mine with a pair of vice grips. They're big enough to grab and turn with some vice grips locked on there.
94 YJ (daily driver)
06 VW (hardcore crawler)
View Public Profile Send a private message to %1$s Show currupt4130 gallery
  #5 (permalink)
Old 03-10-2008, 05:08 AM
Member
Real Name: jonsolbe
Rule number 3 for building a bullet proof jeep is to replace ALL torx fasteners! If you can take them to a hardware store and find something else to replace them with, like a bolt, you'd be saving yourself future headaches:)
View Public Profile Send a private message to %1$s Show jonsolbe gallery
  #6 (permalink)
Old 03-10-2008, 09:34 AM
jfrabat's Avatar
Quote:
I dont know... If you have the torx drivers, they are fairly easy to take out. At least easier than a philips head!
  #7 (permalink)
Old 03-10-2008, 10:08 AM
EMTSerks's Avatar
Real Name: Rebecca
They are not normal torx, they have a pin or something in the middle... So now I need to go buy a set of something else? Anyone know the correct size for it? I really would prefer not to buy an entire set for something I am only going to use once... hopefully I'll be able to replace all the torx with hex bolts or something. Had to drill 2 or 3 out. Ugh.
  #8 (permalink)
Old 03-10-2008, 10:10 AM
VT Hokie
Real Name: Sam
Quote:
Grab em with vice grips, seriously.
  #9 (permalink)
Old 03-10-2008, 11:23 AM
jfrabat's Avatar
Those are tamper proof torx. I dont know the size, but I bought my torx set as a tamper proof torx, and they work for both regular torx and tamper proof torx. You can always do as Corrupt says, and take them out with vice grips and replace them, or you can just get the tamper proof torx.
Forum Jump
Roll Cage jporvaz Cherokee, Commander, Wagoneer and Liberty 4 04-25-2007 10:03 AM
Kerry Junkpile General Chat 108 10-21-2004 01:30 AM
Roll Cage MerkL CJ YJ TJ and JK 4 09-30-2004 06:16 PM
YJ or CJ Full Roll Cage JRowe Items for Sale, Trade, or Give Away 2 01-26-2004 10:16 AM
roll cage???? ODAX CJ YJ TJ and JK 1 07-20-2003 08:00 PM
Message Board Statistics
 Subscribe in a reader
