I don't have any voltage going to the coil. I've checked all fuses and are all OK. I think I've checked all relays but don't know if i've found all of them. Need help please!!!
A crank sensor is a component used in an internal combustion engine to monitor the position or rotational speed of the crankshaft. This information is used by engine management systems to control ignition system timing and other engine parameters. Before electronic crank sensors were available, the distributor would have to be manually adjusted to a timing mark on the engine.
had same problem with 89 2.4 changed coil still had no spark changed cps this seem to work.I think Bounty Hunter gave me this advice, my cps was on driver side bell housing good luck, Dave
Crank position sensor
Well I replaced the ASD relay and the CPS still nothing. All fuses are ok. I'm lost at this point. Help please!!!
