Old 03-13-2008, 01:17 PM
Real Name: JKATTY
4.2 power
I have an 88 4.2 with the carter 2b carb. Jeep runs great. Idles perfectly and runs very strong in lower gears. When I bought it the timing was too advanced and the engine would ping. I retarded the timing and did the TFI upgrade which allowed me to then advance the timing a little still avoiding engine ping.
I have never owned a 4.2 but had a 4.0HO in college. Both Jeeps had 33x12.50 tires and factory gears. The 4.0HO would run about 80-85mph but my 4.2 that I currently own will only do about 70mph and will not hold speed in fifth gear. Is this normal for a jeep with this setup and with the tire size I have or do I potentially have a problem somewhere. I hesitate to do anything because it runs so well. Any ideas or suggestions.
View Public Profile Send a private message to %1$s Show JKATTY gallery
Old 03-13-2008, 07:15 PM
lah2420's Avatar
Re: 4.2 power
You've gone from 180hp, I think, to about 112hp with the 88. The tires and the 3.07 gears are killing it somewhat too.
View Public Profile Send a private message to %1$s Show lah2420 gallery
Old 03-13-2008, 07:17 PM
Real Name: Rblue
Re: 4.2 power
Sounds like a bad case of 3:07 gear's.Go to 3:73's or 4:10's and your 5 speed will be right.My 93 yj came with 4.0 HO 3:07's and i could not use gear 5 at all.I changed to 3:73's with 31's Now i can use the hole 5-speed's.I also added the Tera-low 4.3-1 to my T-case and Low range is Wow SUPER LOW..
Hope this will help you.Good luck an'keepon'jeepin
View Public Profile Show RBLUE gallery
Forum Jump
adjusting power steering gain bebel Cherokee, Commander, Wagoneer and Liberty 8 01-30-2005 12:58 AM
Power windows.. limbmkr Cherokee, Commander, Wagoneer and Liberty 1 09-19-2003 12:15 AM
Power seat problem tech_ed Cherokee, Commander, Wagoneer and Liberty 3 07-23-2003 01:03 PM
tips for stock intake *more power Benskate1 Cherokee, Commander, Wagoneer and Liberty 5 07-20-2003 08:00 PM
Loss of power Greywolf General Chat 4 07-20-2003 08:00 PM
Message Board Statistics
 Subscribe in a reader
