Re: 20 gal. Fuel Tank Questions - Help me please
Hay don't bother yourself!
I couldn't take the suspense so it was simple........ I pulled the pump out. So now I know what's what!
I had to pull the pump anyway because I replaced all the original Jeep instrument panel gauges with Sunpro White faced mechanical gauges. I never had much luck with the Jeep gauges, they would work sometimes if they felt like it other times not at all or you couldn't trust them so screw them, I just hope these work OK
The new ones show that the engine charges, has boocoo oil pressure, vacuum is right on & I havent run it up to temp yet but I have no reason to see why it shouldn't be right on the money. I never tried this type of aftermarket fuel gauge but my old one didn't workat all so its got to be an improvement!
I had to go in thru the larger fuel punp opening to install the new sender for the new fuel gauge. If I ever figure it out I'll take some photos & post them. The gauges really look cool!
I took a piece of redwood I had laying around cut it to the size of the original plastic - whittled out the instrument panel plastic to allow the mechanical gauges to fit & walla! A Custom Dash just like on TV!
