Re: Genright Crusher Corners
We made the first attempt to straighten the frame today. We parked a Ford Econoline E-150 van behind the YJ with a chain wrapped around the frame on the YJ driver's side in back. We put a Ford Ranger in front and placed a cumalong from the trailer hitch to the front passenger side YJ frame member. Between that and a sledge hammer, we were able to close the gap by half, almost 3/4.
Unfortunately, both the van and the ranger moved at that point, even with e-brakes set and tires chocked.
We may have to change the set up so we can use the winch instead and hope for a better result.
Does anyone else have a suggestion?
