Old 06-02-2008, 05:00 PM
Real Name: E.J.
4.2l to 4.0 swap? Your advice needed :).
Hi guys, I've got a 1989 Wrangler with an AWD automatic transmission. The things got a lot of mileage so I've been thinking about getting a new motor to replace my tired old 4.2l with a 4.0l fuel injected motor and a new awd auto trans and I'd also like to upgrade the rear brakes from the drum units to disc.
Alright so here are my questions:
1) Would a newer fuel injected 4.0l motor bolt right up in place of the old one without any modifications?
2) Would the tranny fit in there properly as well?
3) Is there a kit out there to swap out the drums and replace'm with discs that don't require any extensive mods..?
4) Would you buy new parts or junk yard pull-a-parts?
5) Would I be better off just buying a newer Wrangler?
6) What do you think it would run me $$$?
I appreciate the advice, thanks.
View Public Profile Send a private message to %1$s Show wannagojeepN gallery
Old 06-03-2008, 12:34 AM
Bounty__Hunter's Avatar
Moderator
Re: 4.2l to 4.0 swap? Your advice needed :).
I would consider a 4.6L stroker, basically a 4.0L engine with your 4.2L crank. It'll bolt in place of your 4.2L engine. You could also rebuild your 4.2L and add a 4.0L HO head for better performance.
As for the rear discs, find a rear axle from a '95+ Explorer, it will have disc brakes, same wheel pattern, and can be found with many of the common jeep gear ratios. Can even be found with a limited slip diff, and relatively easy to install.
Old 06-09-2008, 08:53 AM
Real Name: PAUL
I'm having the 4.2 rebuilt, adding MOPAR fuel injection and headers.
View Public Profile Send a private message to %1$s Show PS89YJ gallery
Forum Jump
Chevy Swap, Help Needed sjo426 CJ YJ TJ and JK 4 09-25-2006 11:49 AM
AX15 (or better) swap advice hoobness CJ YJ TJ and JK 6 12-21-2005 05:07 AM
Engine swap advice needed 1981CJ5 CJ YJ TJ and JK 3 02-10-2004 03:49 PM
Update on Tire Swap situation--More advice geopig CJ YJ TJ and JK 6 01-25-2004 08:56 AM
Rustys vs Blackdiamond 3" Lift (advice needed) lateralus CJ YJ TJ and JK 2 07-20-2003 07:00 PM
Message Board Statistics
Jeepz.com RSS2 Feed
