Old 07-14-2008, 12:35 PM
BlackStick's Avatar
Real Name: Bryce Van Klein
Question 1994 4.0L HO Tuning
I just bought my first jeep about a month ago and it's great in every way except for power. I bought this jeep after my little brother totaled my 1998 Mercury Mountaineer with the 5.0L V8 that got 350+ HP after modifications. Now I feel like I have 6 squirrels pulling me around. I have never tuned a motor before, so be specific. What can I do to give it some balls?
1994 Jeep YJ 4.0L HO (Red)
16" American Racing Rims (Chrome)
Brigestone Dueler A/T Revo P265/70 16R Tires
Rugged Ridge Dual Tube Front Winch Bumper (Stainless)
View Public Profile Send a private message to %1$s Show BlackStick gallery
Old 07-14-2008, 01:27 PM
Itchee96's Avatar
Real Name: Jason
Re: 1994 4.0L HO Tuning
Its a straight 6. It will never have the HP your V8 had, but the torque will make up for it. Change the plugs, get a cold air intake(unless you plan on snorkeling with the jeep), and regear it. If all else fails, slap a turbo or supercharger on it!
You are comparing apples to oranges in relation to power.
Life is a trip, so give me another hit!
SDMF
View Public Profile Send a private message to %1$s Show Itchee96 gallery
Old 07-14-2008, 01:31 PM
BlackStick's Avatar
I knew that it wasn't going to match the V8, but the 1994 YJ weighs about half as much as the 1998 Mountaineer. My objective is to be able to spin the tires on pavement. It is just not possible now. Any other tips?
  #4 (permalink)
Old 07-14-2008, 02:32 PM
Bounty__Hunter's Avatar
Moderator
Your tires are about 3" larger than stock, so regearing the axles a little lower will help greatly. If you're at 3.07 in the axles, consider a set of stock 4banger axles with 3.73 or 4.10 gears, cheapest and easiest route to go.
Replacing the stock airbox and airtube with a performance airtube and conical filter will help quite a bit.
Consider a Firepower ignition kit from 4.0 Firepower Ignition Kit and open the plug gap up to .065".
Then there's performance camshafts and possibly a valvespring change, Hesco Inc. - High Performance Engine Service is a good source.
I have 62mm performance throttle bodies available if you're interested, they flow a lot more than the stock 55mm. In addition, the taper below the throttle plate found in stock throttle bodies is removed which greatly improves throttle response off the line. Only $95 plus a refundable core charge. Email me at bountyhunter AT sija.org if you're interested.
Exhaust header wouldn't hurt, as well as having the head ported and polished.
Once you start tinkering with the power you can consider a wide-band o2 sensor to keep track of the air/fuel ratio, and google 'adjustable map sensor' so you can tinker with the ratio to compensate for the mods and get the most gains.
Happy tuning.
Forum Jump
Vacuum gauge for carb tuning wm69 CJ YJ TJ and JK 2 10-06-2007 07:30 PM
1994 xj parts mufflerman Items for Sale, Trade, or Give Away 7 09-01-2005 12:49 PM
cb radio and antenna tuning currupt4130 General Chat 1 07-08-2004 06:00 PM
2000 4.0 into a 1994 GC? pettit5 Cherokee, Commander, Wagoneer and Liberty 3 07-01-2004 04:25 PM
1994 4.0 Engine jeep379 Items for Sale, Trade, or Give Away 3 07-20-2003 08:00 PM
Message Board Statistics
 Subscribe in a reader
