Old 07-22-2008, 03:17 PM
Real Name: daniel
Need Electrical Help! Newbie Here!
sorry to yell :)
i'm in desperate need of some help. i just purchased a flex-a-lite fan kit for my 05 TJ 4.0.
tried to install it 2 times, WITH an override switch to manually turn it on, as outlined in the instructions.
first time, i fried the controller. evidently it was because of the override switch i used. it was NOT a flex a lite diode protected switch. figures.
so flex a lite sent me a diode and told me to install it in the switch ground wire. all is semi good.
i tapped into the blue/yellow wire on the back side of the AC compressor, and that's when hell breaks loose. i turn AC ON, and the fan clicks on, but then my AC compressor goes NUTZ. grinding noise. (i was told it was a pressure pop off valve on the compressor)
so i unhook the AC wire, and the compressor continues to make the loud grinding noise. it ONLY goes away when i completely disconnect the fan. then, my AC works fine again.
what's up with that? they sent me a new controller and it does the same thing. am i tapping into the wrong wire???? does anyone know if the blue/yellow wire is the correct one? there's actually 2 blue yellow wires in the harness just above the ac compressor... perhaps i got the wrong one????
the one i tapped has 14 volts only when i turn on the AC.
HELP!!!!!
View Public Profile Send a private message to %1$s Show majkowskid gallery
Old 07-23-2008, 09:27 AM
jfrabat's Avatar
Send a message via MSN to jfrabat
Re: Need Electrical Help! Newbie Here!
Take a picture of the AC compressor wires; maybe we can point out the right one that way...
'94 YJ 2.5L, RE 4" Std Lift, Adv. Ad. SYE, Woods Shaft, Alloy Axles with ARB Lockers and 4.88 gears, 62mm TB and TB Spacer, 165A Alternator, Aluminum Rad, BRX Hoses, Taurus e-fan, DCC fan controller, K&N Filter, Gibson Cat-Back, Accell Coil, LiveWires, 19# injectors, 31" tires on AR 15" Outlaw II Wheels, Delta Xenon H4 Headlights, 100W KC Daylighters and 100W Slimlites (Fog), Riptech Wiperboy, Sony sound system (5.25" front, 6X9 rear and 12" SW with amp), Pavement Ends Targa Hard Top.
View Public Profile Send a private message to %1$s Show jfrabat gallery
Forum Jump
Electrical?? jartmess4 Cherokee, Commander, Wagoneer and Liberty 1 07-13-2008 11:00 PM
Electrical Help... Red77CJ CJ YJ TJ and JK 10 12-19-2003 08:28 AM
#^%@& Electrical!!! chinard CJ YJ TJ and JK 2 07-20-2003 08:00 PM
'79 cj7 electrical help! benjlever CJ YJ TJ and JK 2 07-20-2003 08:00 PM
^#%# electrical! jehartma CJ YJ TJ and JK 8 07-20-2003 08:00 PM
Message Board Statistics
 Subscribe in a reader
