Old 07-26-2008, 02:17 PM
woodie92's Avatar
Member
Real Name: chad
Question 360 pulley alignment problems?
ok.... a little explaning so there are no mistakes as to problem or bogus replies......
changing out my 360 in an 82 cj. bought a motor(from 78 wagoneer) to replace motor( year unknown)....
motor swap went fine! i am using the water pump, crank pulley, water pump pulley, fuel pump, basicaly the entire front of engine from my old motor ok....
everything is going great untill i put the water pumpp pulley on and it doesn't line up with the crankk pulley( to far foward by an 1/8" if that)....
so the ? i have is if i used old water pump and all pulleys why am i having this problem? ( casting numbers on the crank pulleys r the same by the way)
only thing i can think of is the dampner is diff? any help from u guys? this is my first amc motor experience.... although i love the torque i've never built one untill now... thanks for reading this really long thread!
View Public Profile Send a private message to %1$s Show woodie92 gallery
Forum Jump
A/C clutch pulley? CherokeeGuy42 Cherokee, Commander, Wagoneer and Liberty 3 12-12-2007 08:50 AM
Question on clutch fan pulley Psomion Cherokee, Commander, Wagoneer and Liberty 14 02-11-2007 05:06 PM
Harmonic balancer pulley? nkdskls1 CJ YJ TJ and JK 3 10-01-2005 12:11 AM
Where does the York idler pulley attach to? Craig CJ YJ TJ and JK 2 02-25-2004 07:32 PM
water pump pulley? wm69 CJ YJ TJ and JK 5 09-27-2003 12:11 PM
Message Board Statistics
 Subscribe in a reader
