Old 07-27-2008, 01:06 AM
Jeeper99's Avatar
Real Name: Jon
Rough Country X-Series Suspension
I have a 99 TJ sport that is basically stock minus the updated 31X10.50 tires. I am in the planning stages for a 4" lift. Have any of you guys or gals ever used the Rough Country 4" X-Series suspension kit?
I've read alot of info and I like what I see especially with the quick disconnect sway bar links as well as it's in my price range for the updated lift. I pondered on a 6" lift, but after that and buying the slip yoke eliminator etc.... that will be way over my budget at this time.
I appreciate any and all info and tips. Take Care!
Jeeper99
OIIIO
View Public Profile Send a private message to %1$s Show Jeeper99 gallery
Old 07-28-2008, 06:13 PM
Grass Roots VP's Avatar
Real Name: Chip
Re: Rough Country X-Series Suspension
Never heard a good word about Rough Country. The price is right but that's about it.
View Public Profile Send a private message to %1$s Show Grass Roots VP gallery Grass Roots VP
Old 07-28-2008, 09:09 PM
Dragin's Avatar
Real Name: Steve
Quote:
Well your about to hear one. I use a 6 inch system, granted for a YJ but still Rough Country. Anyways the product is quality installs without a hitch and there customer service and shipping is second to none and very friendly people. Ride is fine as well, No worse than factory.
View Public Profile Send a private message to %1$s Show Dragin gallery
  #4 (permalink)
Old 07-29-2008, 02:01 AM
Jeeper99's Avatar
Real Name: Jon
Thanks for the replies. Dragin, for your yj, other than the 6" suspension lift, did you have to change anything else in the driveline due to vibrations? I'm not familiar with the yj's as much, so that's why I was wondering. I know for mine to have a proper 6" lift, I would have to get the CV Axle along with the slip yoke eliminator.
Jeeper99
  #5 (permalink)
Old 07-29-2008, 11:27 AM
Dragin's Avatar
Real Name: Steve
Yes I did have to put in the sye and drive shaft, but it also seemed like a no brainer to me to prevent any vibrations or problems because I also swaped in a Ford 8.8 rear at the same time. Hope that helps
  #6 (permalink)
Old 07-29-2008, 11:35 AM
Utah_jeepster's Avatar
Send a message via AIM to Utah_jeepster Send a message via MSN to Utah_jeepster
With a 4 and or a 6 inch lift you will also have to get extended brake lines, Shocks and a drop pitman arm for your steering along with a SYE kit and the longer CV drive line. The 4 inch lift puts you right at the recommended point for the SYE, some here say you can get away with a transfer-case drop kit for a temp fix till you can afford to buy a SYE kit and new drive lines.
The tricky part is not being able to drive it in....but being able to drive it out.
2001 TJ 4" of lift, long arm kit,ARB's F/R with a viair 450c. Custom front bumper,rocker panels, and sliders.
Only 220 miles to Moab
Only 1622 miles to Red's fridge full of (non-utahian) beer
View Public Profile Send a private message to %1$s Show Utah_jeepster gallery Utah_jeepster
  #7 (permalink)
Old 07-29-2008, 05:40 PM
jfrabat's Avatar
Send a message via MSN to jfrabat
I tried the TC drop, and it did nothing to my bad vibes... Granted, mine is a YJ, but I still had to fork up the $$$ to get the CV shaft and SYE. I am now one happy customer!
By the way, they one thing I keep hearing about Rough COuntry is that they really live up to the "Rough" part of their name; ussually people that have them say the ride is very tough... I have RE, though, and have not ridden one, so dont take my word for it (and its not like RE is a smooth ride, cause in the case of leaf strings, the more lift, the more arch, and the rougher the ride!).
'94 YJ 2.5L, RE 4" Std Lift, Adv. Ad. SYE, Woods Shaft, Alloy Axles with ARB Lockers and 4.88 gears, 62mm TB and TB Spacer, 165A Alternator, Aluminum Rad, BRX Hoses, Taurus e-fan, DCC fan controller, K&N Filter, Gibson Cat-Back, Accell Coil, LiveWires, 19# injectors, 31" tires on AR 15" Outlaw II Wheels, Delta Xenon H4 Headlights, 100W KC Daylighters and 100W Slimlites (Fog), Riptech Wiperboy, Sony sound system (5.25" front, 6X9 rear and 12" SW with amp), Pavement Ends Targa Hard Top.
View Public Profile Send a private message to %1$s Show jfrabat gallery
  #8 (permalink)
Old 07-30-2008, 02:06 PM
Real Name: Chip
Quote:
Wait a year from now when those springs are flat as a board. I have several members who have taken off thier Rough Country lifts after less than a year because they flattened out soo bad.
They always end up keeping the Rough Country shocks & components but swap out the springs for BDS or other top notch Springs .... you get what you pay for. Especially with lift kits.
  #9 (permalink)
Old 08-06-2008, 08:32 PM
NeoAnderson's Avatar
Member
Real Name: NeoAnderson
Here's my review of Rough Country......
any questions?
Delete my account please.
View Public Profile Show NeoAnderson gallery
  #10 (permalink)
Old 08-07-2008, 12:41 AM
Bounty__Hunter's Avatar
Moderator
I've seen many Rough Country kits work very well offroad, great kit for the price IMO.
A SYE kit can be had for around $180, and you can shorten a TJ or XJ front driveshaft for use in the rear with the SYE. Good setup on the cheap.
  #11 (permalink)
Old 08-07-2008, 06:57 AM
Real Name: Chip
In all honesty it's more for the mall crawlers, trailer queens or the guy who wheels a few times a year. The springs are garbage and can't take punishment like BDS. The other Rough Country components aren't too bad. It's the springs that are junk.
But nobody can argue with the price. They are by far the cheapest on the market. And that's exactly what your gettin.
  #12 (permalink)
Old 08-07-2008, 09:16 AM
Moderator
I haven't seen many of their leaf spring kits, but have seen the coil spring kits perform fine offroad, and no sagging after several years of abuse.
How many sets are you basing your experience on? Leaves or coils?
  #13 (permalink)
Old 08-08-2008, 01:37 PM
I've been wheeling for 20 years and I can't even tell you how many guys i've met who have bought and regreted getting Rough Country. More so YJ Springs. I know at least 5 guys in my club including myself who had issues with Rough Country in the past. Beat the hell out of those springs like we do ..... you'll see what I mean.
View Public Profile Send a private message to %1$s Show skeezer gallery
  #14 (permalink)
Old 08-08-2008, 02:23 PM
Jeeper99's Avatar
Real Name: Jon
As far as price range, what would be the next step up from the 4" Rough Country?
<img src=http://i189.photobucket.com/albums/z154/jonlipford/Toys/011.jpg border=0 alt= />
  #15 (permalink)
Old 08-09-2008, 08:41 AM
Real Name: Chip
I've had Skyjacker under my Jeep for over 2 years now with no sag or problems. It was one of the cheaper liftkits at the time. It's been beaten on by rocks, mud, woods, water, etc., and still going strong. Here's a good place to start.
www.ok4wd.com
Best of luck.
  #16 (permalink)
Old 08-09-2008, 09:13 AM
Moderator
Quote:
Rustys Offroad has decent kits at a great price, unless the GRJC guys say it too is for trailer queens that don't wheel as hard as they do
  #17 (permalink)
Old 08-10-2008, 07:40 PM
mrfast's Avatar
Member
You may want to look at a Full Traction 3 inch economy lift, very good reviews and comes with a adjustable front track bar.
97 Jeep TJ Sport, 3" Full Traction lift, 1" body lift,Brown Dog 1' mml, 32x11.50's, cb, disconnects, Winch, warn rocker guards, Warn engine skid plate, Should have bought a Jeep years ago!
View Public Profile Send a private message to %1$s Show mrfast gallery
Forum Jump
bds or rough country? diverdr CJ YJ TJ and JK 24 02-04-2005 11:05 AM
Rough Country Lift jeepfan555 CJ YJ TJ and JK 21 08-26-2004 10:39 PM
Rough Country, good or Bad? Renegade79 CJ YJ TJ and JK 14 02-09-2004 10:50 PM
Rough country suspension allabs5150 CJ YJ TJ and JK 7 10-27-2003 03:48 PM
Rough Country 3" Suspension kit ? Tug-n-pull CJ YJ TJ and JK 3 07-20-2003 08:00 PM
Message Board Statistics
 Subscribe in a reader
