Welcome to Jeepz.com.
Results 1 to 5 of 5
    93YJ's Avatar
    93YJ is offline Junior Member
    93YJ is
    has no status.
    Aug 2008
    2
    93 AX-5 to a 95 or 96 AX-5 problem!
    Hey guys...maybe someone can help me out.
    93 Wrangler, 93 AX-5 went bad.
    Soo...I purchased a 95 or 96 AX-5 (not sure what year but I know that my '93 has an internal slave cylinder, the "new" tranny I installed has an external slave cylinder.
    I swapped my old bellhousing onto the new tranny as well as the front bearing retainer. The newer trans had a bearing retainer on it with a metal sleeve which covered half of the shaft (input or output, whatever one is on the engine side) so I couldn't use my internal slave cylinder.
    By swapping these retainers, I was able to convert this newer tranny to the old internal slave cylinder.
    Problem is, now the slave cylinder is whining like a baby, and I'm not sure if what I did is the reason for the noise. It shifts perfect, and this slave cylinder made NO noise in the old transmission.
    Makes me think I need to put the originall bellhousing/external slave cylinder back on? Please help!!!
    Bounty__Hunter's Avatar
    Bounty__Hunter is
    working on his new WK
    Nov 2002
    Southern Illinois
    12,249
    Type of Jeep
    YJ Wrangler
    Re: 93 AX-5 to a 95 or 96 AX-5 problem!
    Welcome to the Z.
    Did you clip the internal slave in place on the metal dowel? Did you install a new internal slave with the plastic bands intact?
    Wrangl3r93's Avatar
    Wrangl3r93 is offline Senior Member
    Wrangl3r93 is
    has no status.
    Nov 2005
    Murfreesboro, TN
    662
    I did the same swap on my old jeep and it didn't make any noises
    The poster formerly known as Red93...
    '93YJ 4.0HO, 33x12.50r15 Maxxis Mudder Buckshots, 4.5 RE extreme-duty lift w/ 1" BL, 4.11 gears, Aussie locked front, 1in transfer case drop soon to be replaced by SYE/cv shaft, 2 memphis 10's pushed by a memphis pr500, custom bumpers made by me
    http://www.myjeepspace.com/wrangl3r93
    http://www.tnvjc.org/index.php
    93YJ's Avatar
    93YJ is
    has no status.
    Aug 2008
    2
    Yes, I secured the slave to the metal dowel...no, it wasn't a new slave with the plastic bands still secured, it was the "old" (1 year old) slave cylinder from the original tranny. Maybe it's not bled thoroughly and the slave is airbound?
    It's odd...seemed like a pretty straightforward swap to me. That's my luck, though.
    Wrangl3r93's Avatar
    Wrangl3r93 is
    has no status.
    Nov 2005
    Murfreesboro, TN
    662
    Yeah it was a straightforward swap. You need to pull it back apart to find out the source of that noise because noises usually mean something is being torn up.
  1. Oil problem I-6 4.0
    By Big Island Bump in forum CJ YJ TJ and JK
    Last Post: 01-11-2009, 08:42 PM
  2. I got a new problem..
    By hammertech in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 02-23-2007, 02:28 PM
  3. problem after problem
    By B.Jones in forum CJ YJ TJ and JK
    Last Post: 12-14-2003, 10:19 PM
  4. Having a problem with my XJ
  5. problem!!!!!!!!!
    By MudderChuck in forum CJ YJ TJ and JK
