Old 09-08-2008, 01:19 AM
Real Name: Jeepboogie
Tranny or Transfer Case?
After a great day of easy wheeling, pulled into my favorite burger bar. After a short pitstop, jumped back in my CJ for the ride home. Put it in reverse and let off the clutch.....only to roll into the tree in front of me. Then found I could shift into every gear without touching the clutch, but gears wouldn't engage. Figured clutch wasn't releasing, so I messed around with the linkage and sure enough it let loose, but...then the real problem. Now in 4th gear it hits 3000rpm at 25mph, 3rd at 15mph, and so on. Clutch is not soft and it shifts fine, so that doesn't seem like the problem. My only ideas are that it is stuck in 4L or somehow the gears have slipped. First step is going to replace the TC and Tranny fluids to see if I get lucky. Anyone experienced this?
'83 CJ5 - Nutter Bypass, DUI Ignition, Mean Green Starter/Alt
"Damn boy, that jeep is full tilt boogie!"
View Public Profile Send a private message to %1$s Show jehartma gallery
Old 09-08-2008, 01:22 AM
Re: Tranny or Transfer Case?
Forgot the important details: 1983 CJ5, 258ci, T176 tranny, Dana 300 TC, reverse shackle lift, 31" tires, mostly stock except engine upgrades.
Old 09-08-2008, 09:07 AM
Bounty__Hunter's Avatar
Moderator
Sounds like the clutch linkage was screwed up and you got it fixed, pretty common on CJ's with clutch linkage when the frame flexes offroad. Now it is stuck in 4lo. I don't think changing any fluids will do anything for you.
There are some conversion kits out there to change your manual clutch over to hydraulic like the Wranglers.
Forum Jump
Tranny or Transfer case leak? evanp1217 Cherokee, Commander, Wagoneer and Liberty 7 08-04-2008 10:57 PM
What kind of oil in tranny and transfer case? Avs_Fan CJ YJ TJ and JK 1 09-07-2005 10:05 AM
Tranny to transfer case seal...? hoobness CJ YJ TJ and JK 3 06-23-2005 12:27 AM
How do I identify my tranny and transfer case scotts-scrambler CJ YJ TJ and JK 2 07-20-2003 08:00 PM
axle, tranny, transfer case? cjseven84 CJ YJ TJ and JK 1 07-20-2003 08:00 PM
Message Board Statistics
 Subscribe in a reader
