    Nov 2008
    73
    Rear Pinion Torque
    I have a 2001 Jeep Wrangler 4.0L with a Dana 44 Rear Axle and was wondering if anyone knows the Torque Specs for the Rear Pinion Nut. Thanks again Jeepers!
    Utah_jeepster's Avatar
    Utah_jeepster is offline Moderator
    Jun 2003
    Tempe, Arizona
    3,482
    Re: Rear Pinion Torque
    15lbs drag torque once set, its about 210lbs while holding the yoke.
    But it needs to spin with about 15lbs of resistance since there is no crush collar.
    blatant jokessubliminal sarcasmsexual innuendo
    Nov 2008
    73
    How do you set the Drag Torque??
    Bounty__Hunter's Avatar
    Nov 2002
    Southern Illinois
    13,223
    You gradually increase the torque while occasionally checking the drag torque to see if it's within spec. The drag torque is generally checked with a in./lb. torque wrench.
  1. Rear pinion seal
    By graewulf in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 02-03-2008, 07:03 AM
  2. Pinion nut torque.
    By lah2420 in forum CJ YJ TJ and JK
    Last Post: 11-21-2007, 02:35 PM
  3. rear pinion seal
    By wm69 in forum CJ YJ TJ and JK
    Last Post: 05-08-2004, 09:05 PM
  4. rear pinion seal leak
    By bryanjeep in forum CJ YJ TJ and JK
    Last Post: 11-22-2003, 10:57 AM
  5. rear pinion
    By MudderChuck in forum CJ YJ TJ and JK
Tags for this Thread
