Results 1 to 6 of 6
Thread: no 4x4 light
01-02-2009, 12:03 AM #1
no 4x4 light
hi everyone i am sorry to keep askin so many questions but the replies have been awesome I am a first time jeep owner and i love it. trying to fix up my 99 tj i noticed the 4x4 light doesnt come on but i do have 4 wheel drive. any help as always appreciated
01-02-2009, 12:32 AM #2
Re: no 4x4 light
As with many things small things that you're likely going to notice wrong with a 10 yr old vehicle, you've gotta decide how much work and time you're willing to invest. Personally, I wouldn't chase the problem or rip the dash apart. I'd just drive it.
2005 Rubicon, 4inch Skyjacker, 750W inverter, on-board air front and rear, ARB front bumper w/ 2x55W Hella spots & 8kMM, rear swing away with 4x55W CAT work lights and custom jamboree rack with ammo cans, 2x5ga jerry cans, axe, shovel, pintle hitch, Sierra Off Road Trailer.
01-02-2009, 12:37 AM #3
Re: no 4x4 light
fair enough I dont mind investigating a bit i was wonderin if maybe a wire or something underneath could have been the problem.
01-02-2009, 06:44 AM #4
Re: no 4x4 light
There is a Connector on the 4wd switch mounted on top of the t.case. disconnect that connector, verify that the two Wires are Black/ red and Black . Use a small paper clip to run a jumper across the two terminal. turn the ignition on and see if the 4wd is illuminated. if not check the bulb or the wiring on the cluster. IF it does light up with the jumper, replace the 4wd switch on the t.case.
01-02-2009, 08:49 AM #5
Re: no 4x4 light
^^What he said, it's either the bulb, 4wd indicator switch on transfer case, or wiring in between.
01-02-2009, 12:22 PM #6
Re: no 4x4 light
thx guys i will check on that.....
Super need help on doing a fog light/light bar setup
By Kanifler in forum Cherokee, Commander, Wagoneer and LibertyReplies: 0Last Post: 07-28-2008, 01:09 PM -
light bar light wiring routes
By 95yj in forum CJ YJ TJ and JKReplies: 6Last Post: 02-23-2005, 10:03 PM -
blue gas light, blue battery light
By johnny7point0 in forum CJ YJ TJ and JKReplies: 1Last Post: 09-01-2004, 01:58 AM -
looking for jeep decal for 3rd brake light or jeep light
By sparkyshotrods25 in forum Cherokee, Commander, Wagoneer and LibertyReplies: 2Last Post: 10-22-2003, 06:16 PM -
I need a light bar
By dingus in forum Cherokee, Commander, Wagoneer and LibertyReplies: 8Last Post: 07-20-2003, 07:00 PM
LinkBack URL
About LinkBacks
