Welcome to Jeepz.com.
Results 1 to 6 of 6
    freedomfly's Avatar
    freedomfly is offline Member
    freedomfly is
    has no status.
    Aug 2008
    96
    Type of Jeep
    TJ Wrangler
    Gas gauge problems..
    Ever since i bought this jeep it has had a bad gas gauge(well actually it might not be the gauge). Whenever i fill up it goes to full, but when i am completely empty it only shows as half full. It also doesn't slowly move, it just jumps.
    I have been told that this is actually somewhat common in the '93 YJ's. Has anyone had experienced this before? The guy that i bought it off of said that it could be just a ten dollar fix that he never got around to.
    Does anyone have any idea on what to do??
    Thanks
    SteelHeadz's Avatar
    SteelHeadz is
    in need of gears for the front and rear axles. ;(
    Oct 2008
    Kerrville, TX
    5,841
    Type of Jeep
    CJ7/ AMC 360
    Re: Gas gauge problems..
    Idea?, My first choice would be the Sending unit. i could be wrong.
    freedomfly's Avatar
    freedomfly is
    has no status.
    Aug 2008
    96
    Type of Jeep
    TJ Wrangler
    yeah that was my first idea, but that is an option that i put on the end of the list bc of the price.. could it be anything with the fuses
    SteelHeadz's Avatar
    SteelHeadz is
    Oct 2008
    Kerrville, TX
    5,841
    Type of Jeep
    CJ7/ AMC 360
    Since the fuel Gauge has somewhat a response to the amount of fuel in the tank, that rules out a fuse issue. from what it sounds like, the rheostat on the Sending unit is shorted.
    Bounty__Hunter's Avatar
    Bounty__Hunter is
    working on his new WK
    Nov 2002
    Southern Illinois
    12,269
    Type of Jeep
    YJ Wrangler
    Pretty common to all YJ's, not just the '93. Check the contacts on the back of the fuel gauge, you can clean them with a pencil eraser. Otherwise I'd clean the striker contact where the float arm sweeps across the sending unit.
    freedomfly's Avatar
    freedomfly is
    has no status.
    Aug 2008
    96
    Type of Jeep
    TJ Wrangler
    ok.. i will give that a try.. thanks
  1. Air gauge
    By Tuff Jeeper in forum CJ YJ TJ and JK
    Last Post: 01-02-2009, 08:59 AM
  2. YJ Temperature Gauge / Gauge Cluster
    By daveplot in forum Items for Sale, Trade, or Give Away
    Last Post: 04-17-2006, 08:50 PM
  3. fuel gauge and oil pres. gauge not working
    By 1981CJ5 in forum CJ YJ TJ and JK
    Last Post: 09-17-2003, 07:44 PM
  4. diagnosing oil pressure (sender/gauge) problems
    By RAVEN13xxx in forum CJ YJ TJ and JK
  5. YJ gas gauge...(funky problems)!
    By MORGSTER in forum CJ YJ TJ and JK
