Weber carb vacuum diagram
jay89
I thought everyone who installed a weber said it is easy. Everything is going great except for the 1000 feet of left over vacuum hoses. Does anyone have pics or a diagram of how they routed the hoses for the weber. The directions aren't too clear. It sems like you run a direct hose fron the vacuum advance on the distributor to th vacuum advance port on the carb. Then run a direct hose from the EGR valve to the egr Port on the carb after unscrewing the plug in the port? So what the hell gets connected to the CTO or does it get capped.
[addsig]
