Results 1 to 6 of 6
Thread: 89 yj problem
02-18-2009, 10:43 AM #1
89 yj problem
i have a 89 yj 4.2 that will start sometimes and than it won't .when it wont start there is no spark from coil [new coil] go out later and it starts got me puzzled?? Any ideas would be great
02-18-2009, 11:23 AM #2
Re: 89 yj problem
How is you grounds? What about your battery cables?
02-18-2009, 02:02 PM #3
Re: 89 yj problem
turns over great cables good ground good would not start today but let it roll down hill and poped the clutch fired right up. Than quit just like i turned the key off
02-18-2009, 02:12 PM #4
Re: 89 yj problem
Maybe someone else who has a 4.2 could help you. My wife has a 88 yj with 2.5. I know on hers it has a CPS crank position sensor. I also know that they are have be known to fail. Which should turn of the spark.
02-18-2009, 06:08 PM #5
Re: 89 yj problem
hey thanks for the help found out that the junction box where hot wires connect was loose .been starting all day. We will see if that works.
06-08-2009, 02:45 AM #6
Re: 89 yj problem
I have done the fore dist and coil upgrade and it was an amazing diffrence and EASY to do. If you have not I would definitaly recomend it!
93 AX-5 to a 95 or 96 AX-5 problem!
By 93YJ in forum CJ YJ TJ and JKReplies: 4Last Post: 08-04-2008, 10:09 PM -
I got a new problem..
By hammertech in forum Cherokee, Commander, Wagoneer and LibertyReplies: 1Last Post: 02-23-2007, 02:28 PM -
And another problem.
By CherokeeGuy42 in forum Cherokee, Commander, Wagoneer and LibertyReplies: 2Last Post: 08-09-2005, 08:48 AM -
Who else is having this problem??
By L33TJ33P in forum CJ YJ TJ and JKReplies: 9Last Post: 06-03-2004, 09:57 AM -
4 x 4 problem
By billyboy72 in forum CJ YJ TJ and JKReplies: 8Last Post: 07-20-2003, 07:00 PM
LinkBack URL
About LinkBacks
