knocking sound from transmission area in my TJ
UrbanJeep
I have my 00 TJ 4.0 and its ususally a from a stop and i give it like 1/4 throttle or higher you will here a few knocks and then it will stop.. Sometimes and I do stress sometimes if I make a small jerk on the steering wheel a will here a quick knock too... btw its a automatic too so I have no clue.. maybe a U joint going bad?? or somethings loose? dunno
[addsig]
1050887
If it's a u-joint you'll hear a loud noise when first put into gear...particularly reverse...happened on my Grand Cherokee with an automatic...[addsig]
1050888
o, by the way...if you hear it in your steering...check your suspension too, it might be due to initial torque load on the suspension...but chances are it won't be easy to find if it's only little suspension play[addsig]
1050894
Check the transmission mount and the torque mount on the transfer case. Also check your motor mounts for wear. Make sure the transfer case linkage is tight.[addsig]
1050969
when i put it into drive its a pretty big thunk too and in reverse[addsig]
