Results 1 to 8 of 8
Thread: Good idea or bad idea
03-06-2009, 03:10 PM #1
I just found a 3" body lift for my LJ. Is this a good idea or will it make my Jeep look really goofy? I'm thinking I should be patient and save the loot for a combo suspension/body lift for long term use. I am aware that I will have to install a motor mount lift and the transfer shifter will have to be changed in one way or another. BTW my LJ is an automatic. Has anyone here used this type of lift and could you please post the pros and cons of it. Thanks in advance!!
03-06-2009, 03:36 PM #2
Re: Good idea or bad idea
The most Body lift you'd want is 1". Anymore than that is considered dangerous. A 3" suspension lift will be a better choice.
03-06-2009, 06:57 PM #3
edit, see below
DRILL PRESS: A tall upright machine useful for suddenly snatchingflat metal bar stock out of your hands so that it smacks you in thechest and flings your beer across the room, splattering it againstthat freshly painted part you were drying.
03-06-2009, 07:00 PM #4
Most body lift you want is 0". It looks retarded.
84 CJ7 SOA 35" Muds 4:56 locked otherwise restored to original glory.
03-06-2009, 07:01 PM #5
oh wow. Body lift. Was thinking suspension lift >_<.
Any Body lifts are retarded.
I saw a pickup with a 4 inch body lift it looked like. I almost puked.DRILL PRESS: A tall upright machine useful for suddenly snatchingflat metal bar stock out of your hands so that it smacks you in thechest and flings your beer across the room, splattering it againstthat freshly painted part you were drying.
03-06-2009, 09:34 PM #6
Im with SteelHeadz on this. I wouldn't go over 1'' of body lift.
03-07-2009, 05:39 AM #7
You dont notice a 1" body lift on Jeep.I would not go any larger though.
03-07-2009, 11:51 AM #8
Cut then inhalf, sell the other half or give them away, measure for longer bolts.
Parting out postal Jeeps--Good prices? I have no idea
By GaryMB in forum All other Jeep modelsReplies: 5Last Post: 05-28-2012, 09:10 PM -
undercoating..... good idea / bad idea
By mercab18 in forum CJ YJ TJ and JKReplies: 4Last Post: 05-16-2008, 04:19 PM -
Does SOA + 4" lifted Springs = good Idea?
By hoobness in forum CJ YJ TJ and JKReplies: 15Last Post: 08-03-2005, 08:14 PM -
2 inch body lift on an 85 cj7, good or bad idea?
By bigbronco in forum CJ YJ TJ and JKReplies: 3Last Post: 08-24-2003, 10:15 PM -
16º pinion angle good idea???? HELP!
By jeepthing07 in forum CJ YJ TJ and JKReplies: 0Last Post: 07-20-2003, 07:00 PM
LinkBack URL
About LinkBacks
