You will need a Hub Puller. See Picture attached.. Remove wheel, Brake drum, Hub nut, and then install the puller to remove the hub. There are 4 bolts on the back of the axle flange. Remove these bolts and pull the axle shaft with the seal and bearing. Reverse procedure for installation.
