This section
Sponsored By
07-02-2009, 08:20 AM
Member
Jeep :
Year :
Lift :
Tires :
Re: diff fluid? with arbs
how fast do you drive it jfra? mine seems to only do it at interstate speeds. 70-80. mine has 4.10s and a super 35. how hard./easy is it to adjust rear pinion. im not sure if mine is or not?
2002 TJ 6in Fabtech long arm Lift 35x12.50 pro comp xt mts arbs front and rear tire inflation kit arb snorkel olympic bumpers mile marker 9500 super 30 and 35s yukon 4.10s SYE tom woods driveshaft
07-02-2009, 08:33 AM
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1994
RE 4" Lift (STD)
BFG MT KM2 33"
I drive 65 mph typically (70 at most, but not that often; anything faster on a Jeep and I get scared!). I had my ring and pinion done for me, as it's not so simple and you do need some specialized tools to do it. By the way, I also have a Super 35.
'94 YJ 2.5L, Sperwinch EPi 9.0, RE 4" Std Lift, JKS Trackbar, Adv. Ad. SYE, Woody Shafts, Alloy Axles with ARB Lockers and 4.88 gears, 62mm TB and TB Spacer, 165A Alternator, Aluminum Rad, Taurus e-fan w/ DCC fan controller, Borla Cat-Back, Flowmaster hiflow cat, PD Ignition, 19# injectors, Safari Snorkel, 33" BFG KM2 and 15" wheels, Xenon H4 Headlights, KC Daylighters and Slimlites, Sony sound system, Pavement Ends Targa Top, Hanson Front Bumper, JCR Offroad rear, AtoZ Rockers.
07-02-2009, 08:50 AM
Member
Jeep :
Year :
Lift :
Tires :
mine has a slight wine. dont really remember it doing that before i replaced the pinion seal. possible i didnt get the preload right but i marked it and lined it up. that may be whats causing it to get hot and puke fluid. either way i think im going to put another vent in. cant hurt right?
07-02-2009, 09:24 AM
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1994
RE 4" Lift (STD)
BFG MT KM2 33"
It will only be a band ait if you dont find the real problem...
07-03-2009, 10:48 AM
Member
Jeep :
Year :
Lift :
Tires :
i took the diff cover off and there are absolutley no metal shavings. so its probably the pinion bearing whining and getting the fluid hot right? i am going to try and loosen the pinion nut just a hair and change fluid agian
07-03-2009, 10:44 PM
Moderator
Jeep :
Year :
Lift :
Tires :
Real Name: Steven
on the Dana 35's, lift the rear end up( tires off the ground) and re-tighten the pinion nut till you get 15 ft lbs of turning resistance on the pinion nut, to get the right preload on the pinion bearings, some where around 200 ftlbs of torque.
That is where you set the crush sleeve at initial set-up.
The tricky part is not being able to drive it in....but being able to drive it out.
2001 TJ 4" of lift, long arm kit,ARB's F/R with a viair 450c. Custom front bumper,rocker panels, and sliders.
Only 220 miles to Moab Only 1622 miles to Red's fridge full of (non-utahian) beer
07-06-2009, 10:31 AM
Member
Jeep :
Year :
Lift :
Tires :
ok thanks utah. ill try that this evening
07-09-2009, 11:13 PM
Member
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1993
6 inch susp, 2 inch body
33x12.5x15
Real Name: Rob
hey guys...i might have an answer to the diff fluid, but you prob already have it. i have an arb locker and needed fluid.. i got a sheet from arb that tells you different conditions and temp ranges and what to use.
for high temp/desert use (temp range -22 to 212 ) it says use shell S 80W-140 or mobil SHC 75W-90..
let me know if it helps or if you want the other temps ranges
"Loud, proud, and country by the grace of god" Colt Ford.
| Thread Tools |
| Display Modes |
Linear Mode
