This section Sponsored By
Old 07-02-2009, 03:47 PM
87SixInlineYJ's Avatar
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1987
2"
31"
Question Dual Battery Setup w/ Mean Green Altenator
Has anyone done the double battery setup with two optima batteries and a mean green altenator.
I found this article, looks like a good write-up; 4 Wheel Drive & Sport Utility Magazine
I know that some guys have problems with their winch setups to include additional electrical requirements that are demanded by jeep lovers... Anybody been there done that yet?
USMC Low Crawler
View Public Profile Send a private message to %1$s Show 87SixInlineYJ gallery
Old 07-02-2009, 04:22 PM
SteelHeadz's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
CJ7/ AMC 360
1981
4.5
35x14.5 15 Pittbull Krawlers
Real Name: Mikey
Send a message via MSN to SteelHeadz Send a message via Yahoo to SteelHeadz
Re: Dual Battery Setup w/ Mean Green Altenator
I have a dual optima setup on my CJ. I use the 1 most of the time but at night when i use the light bar and the winch i switch the aux battery on..I monitor the aux batt. with a gauge and when it's below 11.2 volts i switch on the toggle when the engine is running so that it gets charged back up and ready for use when needed.. My alternator was custom built with an output of 170 amps and is more than sufficient for all the electrical demands. All my exterior lamps exept the driving and spot lamps are converted to L.E.D.s..I can leave the parking lamps on for 5 to 6 hrs without killing the battery..
Confucious says: I am not one who was born in the possession of knowledge; I am one who is fond of antiquity, and earnest in seeking it there.
View Public Profile Send a private message to %1$s Show SteelHeadz gallery
Old 07-02-2009, 05:05 PM
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1987
2"
31"
Thats freaking awsome! Ok so right now I have a yellow top optima. Im thinking about the mean green altinator. I hear that thing pumps out some major power.
Sounds like you have a pretty cool put-together!
USMC Low Crawler
  #4 (permalink)
Old 07-02-2009, 05:23 PM
SteelHeadz's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
CJ7/ AMC 360
1981
4.5
Real Name: Mikey
Just make sure you have some sort of an isolator from one battery to the other. Avoid leaving the 2 batterys connected together when the veh. is parked..
  #5 (permalink)
Old 07-02-2009, 05:51 PM
Ggg Ggg is offline
Real Name: Gregg
There are s few different ways to run dual batteries. There are pros and cons to all of them. I run my dual batteries in parallel which gives me 12v but double the amperes. I do not run a battery switch or isolator, they perform like one large battery, and it is very simple as in the KISS principal. No special alternator wiring either.
I am not trying to say one method is better than another. Also to get into the science of the pros and cons is beyond the scope of what I want to discuss here.
View Public Profile Send a private message to %1$s Show Ggg gallery
  #6 (permalink)
Old 07-02-2009, 05:58 PM
SteelHeadz's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
CJ7/ AMC 360
1981
4.5
Real Name: Mikey
Quote:
Been there done that. It does work well. However, i found out later when 1 of the battery failed, the other battery tried to equalize with the defective battery causing both to have insufficient voltage the next day. So with this in mind, when both battery are being charged by the alternator, both battery are also trying to equalize at the same time..
  #7 (permalink)
Old 07-02-2009, 07:44 PM
Ggg Ggg is offline
Real Name: Gregg
Yes that is absolutely true, and this is really the only down side to a parallel setup. When you replace the batteries they must be done in pairs, no exceptions. In my case one battery is just not enough in winter to start my truck so even if I had one battery isolated and the other goes dead I am still sol. I have only had one time where one battery went bad suddenly.
  #8 (permalink)
Old 07-07-2009, 10:41 PM
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1987
2"
31"
I am wondering, with the stock altenator in my yj right now working with my yellow top battery, I have noticed that the battery has not met that full charge it had when I first installed it. Would it be a good idea altogether an just get a mean green alt to keep the life strong?
USMC Low Crawler
  #9 (permalink)
Old 07-08-2009, 10:47 PM
Ggg Ggg is offline
Real Name: Gregg
When you say "the battery has not met that full charge it had when I first installed it" how are you checking the battery?
  #10 (permalink)
Old 07-09-2009, 08:49 PM
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1987
2"
31"
Its just that Im thinking that when I start up, the juice dosent start up as quick on some daysas opposed to others. So i figured a stronger altenator would support the ability to fill up that strong battery. ...... how about a MSD ignition box. Any suggestions there? I just want my jeep to have the support it needs to run like a champ an when I ask, it gives!
USMC Low Crawler
Ruffstuff Dual Optima Battery Boxes! Dan Fredrickson 4x4 Vendors 2 06-14-2009 11:54 PM
Dual battery system... cewtwo General Chat 3 10-07-2005 04:49 PM
Mean Green starter... Joopin CJ YJ TJ and JK 5 06-15-2004 04:21 PM
mean green dual battery tray LGR CJ YJ TJ and JK 3 06-09-2004 09:09 PM
Dual Battery Tray for CJ 7 2jeep2think CJ YJ TJ and JK 0 01-25-2004 12:31 PM
 Subscribe to our RSS feed
