Welcome to Jeepz.com.
Results 1 to 2 of 2
    tmaddox's Avatar
    tmaddox is offline Junior Member
    tmaddox is
    has no status.
    Jun 2009
    Alabama
    1
    Type of Jeep
    Renegade
    Gas Gauge quit working
    I just purchased this 1991 Wrangler Renegade ang the gas gauge just quit working.With the motor off,The gauge reads on "E",when you start the motor,it goes straight to "F".Is this a short in the wire?Thanks
    SteelHeadz's Avatar
    SteelHeadz is
    in need of gears for the front and rear axles. ;(
    Oct 2008
    Kerrville, TX
    5,841
    Type of Jeep
    CJ7/ AMC 360
    Re: Gas Gauge quit working
    I would have to assume that the signal circuit is shorted to ground or the sending unit itself is stuck or shorted.. Disconnect the fuel sending unit wire from the module and see if goes back to empty. If it does, the problem is in the fuel sending unit.
  1. gauges quit working?
    By Mxpx182lit in forum CJ YJ TJ and JK
    Last Post: 02-22-2005, 03:04 PM
  2. Cruise control quit working.
    By woody-wagon in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 03-24-2004, 12:58 AM
  3. Radio, A/C, and cigarette lighter all quit working.
    Last Post: 10-22-2003, 11:29 AM
  4. fuel gauge and oil pres. gauge not working
    By 1981CJ5 in forum CJ YJ TJ and JK
    Last Post: 09-17-2003, 07:44 PM
  5. 4x4 quit working...
    By Jeepr89 in forum CJ YJ TJ and JK
