Welcome to Jeepz.com.
Results 1 to 10 of 10
    jonathanstampf's Avatar
    jonathanstampf is offline Junior Member
    jonathanstampf is
    has no status.
    Aug 2009
    8
    94 Grand Cherokee 4WD/AWD 4L won't go into overdrive
    I've been trying to figure out why the jeep won't go into overdrive. 15 mpg is not doing me any good.
    The O/D OFF switch is a pushbutton, with a light above it that lights when you opt for no overdrive. I pulled the wire harness off the back, and drove: no overdrive. I then connected the wires that the O/D OFF switch would close and drove: still no overdrive.
    I put it all back together and noticed that the light stayed on no matter how many times I pressed the button. But interestingly, when the ignition is on the RUN position, but engine not running, the O/D OFF switch will turn that little light on and off. I think this is a key clue.
    I've learned there's a little computer Transmission Control Module that tells the transmission electrically when to shift, and one fellow thinks the Throttle Position Sensor, one thing that feeds data to the TCM, could be the culprit. I checked the Throttle Position Sensor and it sends .2 - 5 volts to the TCM, depending on the position, and is $28. The TCM is $412. So you know what I'm hoping.
    Any ideas? Why does the switch function not running but stays lit when running?
    jonathanstampf is
    has no status.
    Aug 2009
    8
    Re: 94 Grand Cherokee 4WD/AWD 4L won't go into overdrive
    On more thing. I learned that when you replace the TCM, there's an electronic device that syncs it to your trans...something about optimizing shifting. This car had a recently replaced trans when I bought it...could not syncing it to the existing TCM when installed cause this?
    54cj3b's Avatar
    54cj3b is offline Senior Member
    54cj3b is
    Tired of having cancer
    Aug 2009
    Evergreen,Colorado
    1,524
    Type of Jeep
    Willys cj3b
    overdrive in 4 lo or hi you dont run overdrive in 4wd hellooooooooooooooooo
    ALL I OWN ARE JEEPS!
    54CJ3B ,76DJ5RHD , 81DJ5RHD, 88XJ , (It's)93XJRHD(Alive), 06KJ ,
    Bounty__Hunter's Avatar
    Bounty__Hunter is
    working on his new WK
    Nov 2002
    Southern Illinois
    12,249
    Type of Jeep
    YJ Wrangler
    It's a common problem, and I suspect it's one or both of the solenoids inside the transmission, accessible by removing the pan. Common to ZJ's and Dodge trucks.
    jonathanstampf is
    has no status.
    Aug 2009
    8
    That's what we're all looking for, isn't it : a common problem that's easy to fix. Thanks Bounty Hunter, I'm off to learn about solenoids.
    jonathanstampf is
    has no status.
    Aug 2009
    8
    Changed the two solenoids and got no difference. I'd like to re-consider the problem: not that the transmission won't go into overdrive; it seems it's not being directed to ever go into overdrive.
    This has got to be the key symptom: the light over the O/D OFF switch always stays on when the engine is running...no matter how many times I press the button. However, the light will go off and on when I press that button if the key is in the on position but engine not running.
    So I think some sensor on the engine is sending some signal when running that prevents the car's system from allowing overdrive.
    Any ideas along that line?
  7. #7
    SteelHeadz's Avatar
    SteelHeadz is
    in need of gears for the front and rear axles. ;(
    Oct 2008
    Kerrville, TX
    5,839
    Type of Jeep
    CJ7/ AMC 360
    Check for a 5volt supply between the PCM and the Trans. solenoid assembly. Also make sure that the fuse #17 on the PDC is getting a full battery voltage out to the solenoid pack.
  8. #8
    drudog1715's Avatar
    drudog1715 is offline Junior Member
    drudog1715 is
    has no status.
    Oct 2009
    1
    Somebody please help. My '95 grand cherokee is doing the same thing and it is killing me. It is so frustrating because you can never control it.
    Driving around town...on the freeway it is just a joke. Terrible gas mileage and slow acceleration.
    Does anybody have a logical answer...please!!
  9. #9
    jonathanstampf is
    has no status.
    Aug 2009
    8
    I tested every contact point in the wire harness while connected to the TCM. I tested DC volts from the contact point to ground. Here's a diagram of the readings I got. #4 connector to throttle position is 1V, increases to about 4 when I press the gas pedal.
    To reiterate: 42re auto trans, 1994 4L inline6, no trouble codes for engine or trans. OD/Off switch turns light off and on with key on/engine not running, but light stays on, no OD, when running. (Sometimes it will work for 5 minutes, about once a month, for no reason.)
  10. #10
    jonathanstampf is
    has no status.
    Aug 2009
    8
    Attached Files Attached Files
  1. Cherokee or Grand Cherokee? Choices? Questions ECT...
    By CJatGuy in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 12-29-2004, 06:14 PM
  2. auto overdrive on TJ
    By jeepinstien in forum CJ YJ TJ and JK
    Last Post: 10-17-2004, 09:54 PM
  3. Grand Cherokee Pitman and Cherokee Driveshaft
    By blazntn in forum Items for Sale, Trade, or Give Away
    Last Post: 06-23-2004, 04:52 PM
  4. Overdrive Rattle
    By JMSeiver in forum CJ YJ TJ and JK
    Last Post: 02-26-2004, 02:01 AM
  5. XJ overdrive trans in a TJ?
    By jeepin916 in forum CJ YJ TJ and JK
    Last Post: 12-15-2003, 08:00 AM
Tags for this Thread
