    confusedone's Avatar
    confusedone is offline Junior Member
    Oct 2009
    3
    Angry How to replace battery cables??
    I have a 1999 Wrangler..and the battery cables are very corroded and more than likely the cause of why my Jeep at times wont start. I've brought it to an auto parts store to have the battery, alternator and starter checked and all are fine so this seems to be the right answer. The cables are pretty bad and if you whack them hard enough to make them move and change the connection slightly it will start right up. When turning the key all the dash lights come on and it clicks it just won't catch. Seems to be the "logical" answer from what I've been reading.
    But my question is...just HOW do you take the old cables off and how to put new ones on??
    I can handle going into the auto parts store and getting new cables that's the easy part...I'm just a Jeep Girl with not alot of money and need to either do this myself or have a guy friend help me!
    Ggg's Avatar
    Ggg
    Ggg is offline Senior Member
    May 2009
    N.W. IL.
    525
    Re: How to replace battery cables??
    Get a mechanically minded person to help you. Also have them clean your battery terminals and put some anti corrosion grease on them.
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,087
    Welcome to Jeepz. I'm pretty sure you'll be able to do this yourself if you have the right tools. The only tools you will need is a set of a 1/4 inch sockets and a 1/4 inch ratchet. The sizes you will need is a 10mm, 13mm and possibly a 14mm i think. The positive cable(Red) has 2 leads, one to the starter solenoid and the other to the power distribution center(fuse box). The Negative cable(black) also has 2 leads. Both of them are grounds. One to the block and one to the body..
    B'ham Jeeper's Avatar
    B'ham Jeeper is offline Senior Member
    Jul 2007
    Birmingham, AL
    518
    First...Welcome to the Z! Where are you located? There might be someone close that could lend a hand.
    The ground cable is real easy, usually just a bolt to a grounded location. With the other cable just notice or take the time to write down or take pictures of how it is connected. This is not a hard fix, just have to pay attention to details...
    54cj3b's Avatar
    54cj3b is offline Senior Member
    Aug 2009
    Evergreen,Colorado
    1,514
    if you dont have any mechanical skills send it out best word of advise I will give you
    ALL I OWN ARE JEEPS!
    54CJ3B ,76DJ5RHD , 81DJ5RHD, 88XJ , (It's)93XJRHD(Alive), 06KJ ,
    Oct 2009
    3
    I'm in the Denver, CO area.
    I have guy friends who are mechanically inclined but doesn't mean they've done this specifically before.
    Taking photos is a great idea!
    Time to hit the auto parts store!
  7. #7
    southtj's Avatar
    southtj is offline Senior Member
    Aug 2003
    Memphis, TN
    3,110
    It should be very easy. Just take off the old and put on the new the same way. Be sure to clean up the battery posts with a wire brush.
  8. #8
    Crazy4diesels's Avatar
    Crazy4diesels is offline Senior Member
    Oct 2008
    Boston
    393
    Check to see if the cables are soldered to the lugs at the battery clamps. If they are soldered you might not need to change the whole cable - just the battery clamps. If they are just crimped (not soldered) and the corrosion has crept under the jacket of the cable turning it green then you might want to change the cables and the clamps. For exact fit cables you'll probably have to go to the dealer. I always pack mine with wheel bearing grease after they are clean to protect them. Best of luck - John
  9. #9
    54cj3b's Avatar
    Aug 2009
    Evergreen,Colorado
    1,514
    pm sent
  10. #10
    Oct 2009
    3
    It's done. At least the positive one which was the really bad one. Having a hard time locating a negative one.
    Thanks for all your help!!!!
  11. #11
    Jul 2007
    Birmingham, AL
    518
    That's great!
    Post up any time, a lot of good people that know how to help with all issues...
  12. #12
    I R Foof's Avatar
    I R Foof is offline Junior Member
    Jul 2014
    1
    I just wanted to say, that I am doing this as well and am having problems finding the proper lengths of cables. But, the big thing is that yes, they do corrode over time, but I have had constant problems with the clamp bolts where the wire meets the terminal. They tend to loosen if you hit a lot more bumps(Jeep) at higher speeds than most. 7/16" socket or wrench to tighten those down should keep you fired up until you get it all replaced.
  13. #13
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    2,952
    This is a really old thread, so you might not get a response from the OP.
    However consider using welder wire and soldering the ends. Look up the big three. Grounds, power and alternator. Many audiophile will do this to keep the static out of their sound system.
    http://www.youtube.com/watch?v=5E2Zuw03jCQ&sns=em
  14. #14
    carnuck's Avatar
    carnuck is offline Senior Member
    Jan 2009
    Seattle
    917
    Also use No-Ox or similar anti-corrosive goop on the connections.
    '87 Comanche 4x4 lifted 5 1/2" on 33" tires 4.0L/AW4/NP242 $3500
    Perfect combination but too small to haul my Grand Kids and wife in.
  15. #15
    Turbogus's Avatar
    Turbogus is offline Senior Member
    Nov 2005
    Albany~town, Oregon
    1,092
    Since I preferred using welding wire for my electrical I went with 2 gauge but the red jacketed kind was impossible to find locally (unless I bought 40 ft.) but I happened on EBay the other week and there's an outfit selling pre made welding wire with lugs. To get the length I needed I went a little long and cut one end off then with these hexagonal hydraulic crimpers I found went to work and I'm right impressed with the results.
    ...unfortunately my Benzomatic ran out of juice before I finished the collar part of soldering.
    Quick fixes are so named for how long they stay fixed.
    If you run out of gas, no matter which way you decide to push, the closest gas station will always be uphill and in the other direction. Corollary: The likelihood of running out increases when all of the nearby gas stations are closed.
    The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep.
    We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch).
  16. #16
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,092
    Finished the project and it looks good and heavy duty, especially when compared with my first attempt with a hobby vise.
  1. Parking brake cables
    By Snitty in forum CJ YJ TJ and JK
    Last Post: 02-27-2011, 04:04 PM
  2. YJ tub or replace cj?
    By greengeeker in forum CJ YJ TJ and JK
    Last Post: 05-01-2004, 10:19 PM
  3. E Brake cables to a D44
    By Joopin in forum CJ YJ TJ and JK
    Last Post: 09-09-2003, 01:49 PM
  4. Alternator, cables, battery or more...
    By RAVEN13xxx in forum CJ YJ TJ and JK
  5. Heater Cables
    By PatriotJeep in forum Items for Sale, Trade, or Give Away
