This section Sponsored By
Old 10-26-2009, 04:14 PM
Real Name: Matt
2005 wrangler unlimited
I recently changed my front pads and rotors, and noticed when i apply a good amount of pressure my jeep pulls to the left, i checked to make sure i installed them correctly and i did. any ideas?
View Public Profile Send a private message to %1$s Show mtetreault1116 gallery
Old 10-26-2009, 04:17 PM
SteelHeadz's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
CJ7/ AMC 360
1981
4.5
35x14.5 15 Pittbull Krawlers
Real Name: Mikey
Send a message via MSN to SteelHeadz Send a message via Yahoo to SteelHeadz
Re: 2005 wrangler unlimited
Welcome to Jeepz.. You tested this on different road surfaces and crown?
View Public Profile Send a private message to %1$s Show SteelHeadz gallery
Old 10-27-2009, 08:22 AM
jps4jeep's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1994
3"
Q's the only TSL
Real Name: Johnny
Send a message via AIM to jps4jeep
Did you clean the new rotors before you put them on? they come from the manufacturer with a coating to keep from rusting, prior to install, you should liberally spray them with brake clean to remove the coating, if not, the coating can prematurely glaze the pads.
It used to be a jeep Thing,
But all that stuff broke
-Johnny-
View Public Profile Send a private message to %1$s Show jps4jeep gallery
  #4 (permalink)
Old 10-28-2009, 03:39 AM
Real Name: Matt
Yes i did clean them with brake clean, and i tested them on a paved road, i read that the ridges that the pads ride on can have grooves that can mess the pad from moving in, they said you can take some sand paper and clean them up and put some lube on them, i think i will check that out, thanks for your imput
Matt
  #5 (permalink)
Old 11-02-2009, 03:13 PM
1ATony's Avatar
Official Vendor
Jeep :
Year :
Lift :
Tires :
Grand Cherokee
2004
Stock
Stock
Real Name: Tony
You might also want to have a buddy help you to bleed the brakes.It's pretty easy to do and it'll get out any air in the lines that might be trapped in there.
Tony
Tony
1A Automotive Parts
866-403-3393
Jeep Parts
Follow Us On:
View Public Profile Send a private message to %1$s Show 1ATony gallery
  #6 (permalink)
Old 11-02-2009, 07:07 PM
Member
Real Name: glenn
if the brakes were clean when installed and have a few miles to bed in then it sounds like contaminated brake fluid proberly got pushed backwards into the pipes when the piston was pushed in to allow for the new pads. (if you undid the bleed screw to get the piston back in then the brakes will proberly need bleeding to remove air, this is common practice in some shops as it avoids brake fluid getting anywhere near the paint) bleed the lines doing passenger side first then drivers. the ridges the pads ride on normally become a problem when the brakes are releasing this causes dragging to one side when not braking. this was common problem on most cars i have worked on in uk so should be the same with the jeep.
View Public Profile Send a private message to %1$s Show glenn beck gallery
  #7 (permalink)
Old 11-05-2009, 06:31 PM
RockCity's Avatar
Member
Jeep :
Year :
Lift :
Tires :
TJ Wrangler
2006
Stock
30"
Real Name: rockcity
Make sure that your caliper slides are free and lubed. You may have one caliper that is not releasing completely and keeping that side engaged or applying more pressure to that one side.
View Public Profile Send a private message to %1$s Show RockCity gallery
  #8 (permalink)
Old 11-08-2009, 07:35 PM
Real Name: Dennis
A lot of good soultions here. Make sure the slides were greased up, make sure no air got into the system (bleed then really good).
If you are still having problems, ask about the priority valve.
These brake systems seem pretty simple, so you are close to curing the problem.
View Public Profile Send a private message to %1$s Show nutz4dirt gallery
2005 Wrangler Unlimited Locking Rear Diff schwagoo CJ YJ TJ and JK 3 05-20-2009 06:54 AM
alternative tire size for 2005 wrangler unlimited trooperjet CJ YJ TJ and JK 5 01-06-2009 08:06 AM
2005 Wrangler Unlimited (Electric Lime Green) ahunt01 Items for Sale, Trade, or Give Away 8 05-21-2006 09:00 AM
2005 Unlimited Rubicon Deerhunter30 General Chat 17 10-06-2004 10:40 PM
 Subscribe to our RSS feed
