This section Sponsored By
Old 10-26-2009, 07:16 PM
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1995
Stock
31"
Real Name: bill
YJ tranny cooler line replacement
I love working on my Yj and keep her pretty clean. This makes it easy to see when my tranny lines to the cooler are leaking
I went to some websites to see about replacing them and all I can find at 4wd.com are some snake clamps and 2 feet of rubber hose
They look sort of cheap and I was never a fan of snake clamps if I did not have to use them. The ones that are factory look pretty solid, possibly even high pressure.
Any thoughts on replacing these? I pulled them off my '76 jeep Waggy when I had her and all it took was some teflon tape to stop the "bleeding".Any vendors that carry replacement kits I would love to hear from you!
View Public Profile Send a private message to %1$s Show zowtiak gallery
Old 10-27-2009, 12:21 AM
Jeep :
Year :
Lift :
Tires :
CJ-5
1978
2-1/2"
33"
Real Name: Kriss
Re: YJ tranny cooler line replacement
Power steering or similar high pressure hose and regular screw tight clamps have always worked for me; never used any sealer or tape. Cheap.
View Public Profile Send a private message to %1$s Show Saddle Tramp gallery
Old 10-27-2009, 01:57 PM
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1995
Stock
31"
Real Name: bill
Thanks!
  #4 (permalink)
Old 10-28-2009, 01:32 AM
carnuck's Avatar
Jeep :
Year :
Lift :
Tires :
Comanche
1988
6"
33/9.50/15s
I use the Dodge auto trans lines. They are the same up to the front.
View Public Profile Send a private message to %1$s Show carnuck gallery carnuck
  #5 (permalink)
Old 10-31-2009, 10:46 AM
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1995
Stock
31"
Real Name: bill
I went to the local Shucks. They have a couple of guys that are pretty knowledgable and suggested i use a 3/8s hose and clamps. I am wondering if I should just byopass the cooler all together. I dont tow, so maybe it is not needed.Hmm. thoughts?
  #6 (permalink)
Old 11-01-2009, 12:11 AM
Jeep :
Year :
Lift :
Tires :
CJ-5
1978
2-1/2"
33"
Real Name: Kriss
Do not bypass the cooler unless you want to rebuild the transmission; heat is the enemy of an auto and it needs the cool.
  #7 (permalink)
Old 11-02-2009, 12:24 PM
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1995
Stock
31"
Real Name: bill
Thanks for the sound advice. I heard that from other sources as well. I am going to try and just put new 3/8 line on it and double clamp it. I will take some ophotos and put it in the tech side and update it if it blows up or not! I heard that the transmission does not have too much pressure behind it so it should hold up.
Here is the kit I saw from 4wd.com. I am thinking about getting it in case the metals lines break repairing mine.
Universal Transmission Line Kit by 4 Wheel Drive Hardware and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware
transmisson oil cooler line removal ???? lordmetalz28 Cherokee, Commander, Wagoneer and Liberty 3 08-31-2009 05:42 PM
Red Line tranny fluid indiemo CJ YJ TJ and JK 10 04-19-2006 04:48 PM
Tranny cooler dbr5010 CJ YJ TJ and JK 5 03-18-2006 07:38 PM
Tranny Cooler GVW? bryanjeep CJ YJ TJ and JK 17 09-09-2004 06:14 PM
YJ 90 Brake Line Replacement advice richsia CJ YJ TJ and JK 2 11-18-2003 08:11 PM
 Subscribe to our RSS feed
